Results 1 to 10 of 12
Thread: Remagnetising vintage drivers
    Default Remagnetising vintage drivers
    Is there anyone in the UK that does this?
    SW1X USB I Signature
    SW1X DAC II Special
    Passive Volume Control
    Ron Welbourne DRD 45 monoblocks improved by SW1X
    SW1X Open Baffle Speakers containing vintage alnico drivers - Grundig tweeters, Saba Greencone midrange and Altec VOTT 416 bass.
    great plains in usa will do it. not much help tho
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, DEEZER HiFi - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm gordan.
    only ALTEC as far as i know
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b (main) or Hiraga La Maison de L'Audiophile 20
    Preamp: Dave Slagle EMIA AVC
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 with Fidelity Research FR64fx (main) or Kuzma Stabi S with 4 Point
    Cartridges: SPU Spirit (main) or Koetsu Black revisited by Salai or Miyajima Shilabe
    Step Up Transformers: Tango MCT 999 (main) or Ortofon T-5000 or Luxman AD8000 with 8030 capsule or Fidelity Research FRT-5 or Lumiere SUT
    Digital: Akai CD-79 modded
    Wires: of sufficient length
    Quote Originally Posted by anubisgrau View Post
    yup think great plains are connected to altec or at least deal with their stuff. dunno if they have a uk section... suppose it might be worth sending away, although its fair to say they may sound different to how they did
    Grant ....
    Something might turn up locally, I guess there are still companies like Lowther doing this. Does anyone know if the total driver is put through the process or do they need to be stripped to isolate the magnet?
    SW1X DAC II Special
    I'm Simon.
    Total driver usually. Check out YouTube for sub driver builds.
    Can Wembley do it?
    Can Wembley do it?
    Cant find any You Tube stuff but have emailed Wembley. Thanks
    SW1X DAC II Special
    I'm frank.
    Apparently, DC Boultons can do Tannoy AlNiCo's but I haven't had an update on whether it was successful or not.
    OK, found there details and will get in touch. Thanks
    D.C. Boultons
    Loudspeaker Repairs
    Unit 12, Damgate Industrial Estate
    Damgate Lane
    ACLE
    Norfolk, NR13 3DJ
    Tel: 01493 750075
    Fax: 01493 751155
    SW1X DAC II Special
    D.C. Boultons
    Loudspeaker Repairs
    Damgate Lane
    ACLE
    Norfolk, NR13 3DJ
    Tel: 01493 750075
    Fax: 01493 751155
    Phone number is now in private hands, so I guess they no longer exist
    SW1X DAC II Special
