Results 1 to 10 of 16
Thread: WTD Durlay underlay cut offs
    Default WTD Durlay underlay cut offs
    This may sound weird but there's logic here. I ordered some small samples from Carpetright a while ago, and recently tried them under my Metrum dac, with very good results. It needs to be the "crumb rubber" type, the most suitable one looks to be System 10. I wanted to buy some but the minimum amount is an 11sq m roll for £70. A bargain in the world of hifi isolation, but a ridiculous amount to have to use. So if anyone has any cut offs put away please could I buy some/pay postage or whatever? Alternatively, does anyone want to do a group buy and split it up?? This might work nicely cut to the shape of the component base with the feet taken off (if it doesn't get very hot), or just under the feet, I want to do some experimenting.
    I'm Mark.
    When I wanted a small amount of underlay to do a quick and dirty patch up job I found some for a few quid in our local independant carpet shop. Obviously left over from a job. If the one you want is not too exotic you might find a bit that way.
    Quote Originally Posted by Len Co View Post
    Yes thought about that but I need to find a local place that does Durulay.
    pm sent
    'ANDSOME IN THE SUMMER..'ORIBBLE IN THE WINTER. Barney Milne
    Cambridge Audio CXN, Seagate nas drive, Michell Gyrodec SE, SME309, Benz M2 Ruby cantilever, Denon DL103, Primare R32, Densen D20, Densen D30, Cambridge Audio 840A V2 integrated, Pioneer SX-N30AE Network Stereo Receiver, Roksan Darius speakers, Technics speakers, Canon speakers, Bastanis Dragonfly Horns, REL Storm III sub, Target R1 speaker stands, Atacama Equinox.
    I'm Phil.
    i got a shed load of screwfix the other day . carpet shops say they don`t do it now . hopefully you get sorted but if not i am sure i can help
    Eric Bibb
    Quote Originally Posted by hifinutt View Post
    Is that for carpeting or hifi use? Yes carpetright have withdrawn the system 10 I'm hoping it's not been discontinued. If you have any leftovers please PM me.
    Out of interest, are you placing the DAC straight on the underlay, or on a platform on the underlay?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    Straight on the underlay. The sample is small so the feet do not touch the underlay and hover. Is a metrum octave mk1 which is small.
    Thanks. I automatically think of valve gear, and blocking of air vents, which doesn't apply with you. My stuff is stood on marble 'chopping' boards, so I may try the under felt under them
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
    Sounds like a plan. I definitely think the rubber type feels better than the foam type (as in more like traditional isolation like sorbothane, but that doesn't necessarily mean it's better for vibration reduction). Would be interested in your findings.
