Page 3 of 28 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 280
Thread: Do mains cables make a difference??
  1. #21
    No worries. The most important thing with a mains lead, used for hi-fi purposes, is to eliminate it acting as an aerial for noise and interference [or at least reduce that effect as far as possible]. In that respect, pay particular attention to shielding.
  2. #22
    I'm sure there has been a discussion or two about this subject before on AOS?
  3. #23
    Bigman80 Guest
    No worries. The most important thing with a mains lead, used for hi-fi purposes, is to eliminate it acting as an aerial for noise and interference. In that respect, pay particular attention to shielding.
    Sound, I'll be very meticulous. Any recommendations for wiring before I go for the floating shield approach?
  4. #24
    Bigman80 Guest
    Defo Jim, I'm sure I've probably read it too lol
  5. #25
    Bigman80 Guest
  6. #26
    I'm Adam.
    Well, at least the 'China Export' mark is nice and clear to see...
    The secret is though, to hard-wire something in place that's decent
    Not at all - you should use the cheapest, thinnest mains cable you can get away with., That way, only the strongest electrons will get through, thus improving your sound.
  7. #27
    Bigman80 Guest
    Quote Originally Posted by Beobloke View Post
  8. #28
    Should be fine - you can't beat a nice wee floater
  9. #29
    Bigman80 Guest
    I'm sorted.
    Your phone needs charging Oliver
