Page 25 of 28 FirstFirst ... 152324252627 ... LastLast
Results 241 to 250 of 280
Thread: Do mains cables make a difference??
  1. #241
    Just to set the cat amongst the pigeons a bit...
    Noticed last night the mains lead from my power amp was pressed against the back wall a bit?
    Moved the amp forward a bit and left a bit of clearance?
    Better sense of space around vocals and better ‘flow’ in well recorded live music.
    Go figure
    Listening this morning and moving amp back to where it was can hear the difference.
    Small tweak well worth doing.
    Not in the slightest bit surprised mate, as I discovered that one years ago!
    It's one of the reasons why I have my kit on multiple layers of Mana supports, because even if they weren't doing anything, in terms of their design (they do, but that's another matter), the very fact that my kit is so high up off the floor, means that I can both let all my cables (mains and signal) hang in free space, and keep them well away from walls.
    The cumulative effect of that is always audible, and as you've discovered yourself, sonically beneficial. If you want to hear another similar upgrade, try and arrange your equipment on the rack so that the box carrying the most sonically influential interconnects is high up enough to allow them to hang in free space, as opposed to touching the floor or walls. And do that with as many bits of kit as you can.
    *And*, if you fancy another tweak, and you use a mains block of some description, place some isolation cones/Sorbothane feet, or something of that ilk under it, in order to raise it up off of the floor (including the power cable attached) - or even better still, if you have a spare shelf on your rack, place your mains block on it, and get it up off the floor that way.
    Trust me, as a result, your whole system will sound better [by de-oupling it from a source of vibration]!
    P.S Nice chunky mains cable and IEC. Like it. What are they, out of interest?
  2. #242
    30 magic mushrooms eaten fresh and washed down with a can of strong, cheap lager. System will sound amazing; I mean musicians not only in the room but you are inside the musician's heads too. System can be as shit as you like, it still works
    And don't forget to put 'Master of The Universe' on. (sounds incredible really loud through big Tannoys )
  3. #243
    I'm Dennis.
    Talk of electrons travelling kilometres is contrary to what I was taught in 'A' level physics.
    The field travels at near the speed of light, but the electrons travel only a few millimetres.
  4. #244
    I thought the perception was that electrons simply oscillate back and forth, each imparting energy to the next in line.
  5. #245
    I'm inactive.
    What we learnt in Physics - even had a Slinky set up to demonstrate the wave principle involved
  6. #246
    I'm Gary.
    Douglas Adams....your thoughts are missed.
    Martin, care to fill in?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  7. #247
    I'm Gary.
    It's a commercial cable, a PS Audio AC5.
    Have an AC-3 powering my Directstream Dac, be upgrading to another AC5 when the pennies are there.
    Uh...seriously?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  8. #248
    Lol.... Coolz. It looks decent value for money, considering the quality of materials used and construction.
    If you can, do try the other stuff I recommended, as I think you'll like the effect. Quite simply, it pays to get ALL your cables up off the floor and away from walls!
  9. #249
    I'm Edward.
    It seems to me that the 'best' mains cable to use is 2.5 mm ring main cable given that it feeds the sockets anyway. A bit stiff but doable. One could always put some nice braid around it to make it look less 'industrial'.
  10. #250
    I'm Gary.
    Quote Originally Posted by Edwardlon View Post
    Nice braid would do that, yes.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
