Page 13 of 28 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 280
Thread: Do mains cables make a difference??
  1. #121
    I'm Neil.
    Pretty much everything other than power cables makes more of a difference in HiFi, so it's one of the last things to look at IMO. For example, spending £50 or so on some well thought out decoupling of components / speakers will make far far more difference. I see a lot of systems where you could sell the expensive power leads & get something like a much better DAC, better speakers, better amps etc. Cables aren't going to 'improve' a system.
    If you feel that a power cord can transform a system, then there should be no problem in doing a blind test.
  2. #122
    I'm Gary.
    On the contrary I'd say that jumping to the wrong conclusions about cause and effect is the worst possible thing for progress. If you don't know how it works then you can't improve on it, except by chance.
    There's plenty of times that a difference is pretty obvious and there's no question that the sound has changed. Then there's those occasions where we think we hear a subtle change. It's only in those latter situations that we have to question what we think we hear. Especially if there is no credible reason for there being any change.
    We have to acknowledge that we can be fooled by our senses because it is a fact that we can be.
    To me that is the practical and realistic approach. Imagination Land is not a good place to be putting a hi-fi system together or doing anything else, for that matter.
    The knowledge that confuses conclusions reminds me of a story:
    There was an Austrian entomologist that was studying grasshoppers and their ability to communicate.
    He found a particular individual that appeared quite forward in this, he named him Johann.
    After extended sessions he taught Johann to jump on command.
    On an experimental whim, the entomologist removed the grasshoppers legs, he gave the command to jump. Nothing happened!
    Pondering on the results, he concluded that removing Johann's legs made him deaf.
  3. #123
    But only if you feel the exercise is likely to have some potential benefit.
    I'm more than happy to conduct blind tests, and indeed have done so many times in the past, but the results are far from conclusive. And by the way, I'm in the subtle, but worthwhile improvement, not "transform" camp. If any mains lead 'transforms' a hi-fi system, then something is badly wrong!
    For me, it's about the balance of probabilities; based on MY judgement of such, no-one else's, so if (by and large) 20 years of experimenting with mains cables, and how the mains in general influences the behaviour of audio equipment, tells me that my conclusions, in that respect, are right, am I going to dismiss all of that simply because of one time I might get the 'wrong answer' in a blind test?
    I think not
    In the final analysis, once you've satisfied your judgement criteria, you need to have CONFIDENCE in your convictions - and STICK WITH THEM, if you're convinced that you're right!
  4. #124
    So if I plug a "computer lead" into a kettle, what may happen?
    I doubt if you could do that - "kettle" leads use a high current capacity IEC connector (16A), which have a keyway. This there to to prevent the possible insertion of a lower rated lead with a lower rated IEC connector (6A) into the kettle.
    Without taking sides in this debate, I ought to pass on my concern with the construction of 'freebie' leads using moulded connectors: you can't check the integrity of the connections. Maybe this is why I prefer to make my own leads.
    I'm Dominic.
    Absolutely, Dominic. And I respect your contrary experience.
    For me, however, there's a danger of allowing your natural senses and thought processes to become bogged down/governed by 'what is deemed as correct', based on currently accepted wisdom. It stifles free thought.
    Maybe 9 times out of 10 currently accepted wisdom is right, but what about the other time when it might not be, or in fact isn't - or are we saying that we unquestionably know all there is to know about cables, and how they influence the behaviour of audio equipment: everything that needs proving has already been proven - and so there is nothing new to learn?
    For me, that's far from the case and constitutes as lazy thinking, liable to stifle progress, just as much as blindly believing in any kind of 'foo', invented by and claimed as true, by cable manufacturers.
    There has to be a point in the final analysis when, if for what you consider to be very good reason, you have the gumption to trust your ears. Quite simply, pooh-poohing everything that contradicts your belief system is no way to learn.
    I think you been a bit too gracious towards accepted 'wisdoms' as to be honest they have only paid lip service to the subject, relying only on resistance, inductance and capacitance as the beginning, middle and end of the knowledge base which has remained virtually static since the 1940's. No, I am mistaken there, they actually realised that current flow direction was actually opposite to what the wisdoms said it was.
    Those measurements being used to evaluate cable performance are flawed because they are primitive in the extreme. For a start, they are purely static measurements and bear no relation whatsoever in the measurement of complex frequencies, interactions and dynamics found in real music reproduction, because they are unable to do so and won't admit that. It is the very reason objectivists throw a smoke screen of pointless accusations like placebo and expectation bias to divert attention away from those shortcomings. No wonder I bristle plenty when they are aimed at me in these debates, because I may be placebo'ed a couple times at most, have some sort of expectation bias a few times perhaps, but after hundreds of times over several decades certainly not and I always challenge these people to show me evidence of prolonged, sustained and repeatable facts that these conditions can be maintained for hundreds of times and spanning decades. They can't, because that evidence does not exist.
    I jokingly said earlier in this thread that a mains cable is not there just to convey electricity from the wall socket to the system without spilling any on the carpet and after deep cogitation for more time than I would admit to, I realised that a mains cable has more demands on it than just that simple job. If you think that it is no more than a narrow bore pipe for a steady trickle of leccy to keep your system well fed with the stuff, then you couldn't be more wrong. The current flow demand can change instantaneously from a mere trickle to a full blown call of 20 amps plus in a millisecond, but, "Aha" you might say, the power supply should provide that, but it doesn't and cannot because where exactly does all this power come from? I was taught many moons ago that a capacitor cannot discharge and charge at the same time and logic says that is true, so while the capacitor is trying to supply peak current for a transient or bass, what happens to the charge cycle for the next transient peak come from? There is always a delay and a poorly built mains cable just adds even more delay, longer in fact than the charge rate of the capacitor. It is the only sensible(ish) answer I could find that addressed the issue of bass boom and overhang from a loudspeaker which miraculously vanished when an upgrade mains cable was installed. This bass overhang is the signature for me that the mains cable is not up to scratch.
    Metallurgy I say also plays a major part with mains cables, not just curing bass overhang but also hiss. I was at a dealers and we were trying out mains cables on a Consonance valve system with corner horns. I noticed that the noise floor and particularly hiss was considerably reduced almost to zero with the pure silver power cord, which shocked me as I thought that hiss was "one of those things" we all had to live with as it was inherent with amplifiers. It is known fact that silver is more conductive than copper but it must also have a different grain structure in the metal but this wasn't confirmed in my own mind until some nice chap in Japan was also similarly inclined to the grain boundary theory and took steps to manufacture copper wire without them. When OHNO cast cables came onto the scene a similar thing happened compared to a normal copper cable, the hiss was substantially reduced. The continuous casting process virtually eliminates the grain boundaries of the metal, so it is not unreasonable to assume that it is those same grain boundaries that gives rise to hiss. The theory is that hiss is a series of millions of microscopic 'explosions' or arcs as the electrical current jumps across these boundaries. Electricity isn't like water flowing through a pipe but an electromotive magnetic force which has no physical contact with the metal itself so I am told, although the evidence seems to contradict this. Here we go again.
    It may be this trait often gets referred to as the music emanating from the proverbial "inky blackness" that many listeners enthuse over.
    CD player = Marantz CD6006
    DAC/pre = Rotel RC 1572
    Power amp = ADA PF201
    Speaks = Quadral Chromium Style 6
  6. #126
    May I also add that Mains cables will almost certainly interact differently depending on the equipment they are used with so where as one person hears no change in their system, someone else may perceive a significant change.
    There are some interesting facts here concerning mains cables which may make sceptical folk think differently about them - or may not?
    https://www.gcaudio.com/tips-tricks/...-a-difference/
  7. #127
    from that link
    Every audiophile who has experimented with better power cables has heard the performance advantage they offer. Indeed, the amount of improvement can be astounding, often transforming a system from good to amazing. As audiophiles, we trust our ears but it’s hard to understand how replacing just one short link in a long chain of the power delivery system can have such a dramatic impact. The following article is intended to answer those questions
    Note the bits in bold.
    Now here is an ABX test where they had to try to distinguish between Nordost power cables and some standard leads supplied with some Parasound amps.
    https://hometheaterhifi.com/volume_1...s-12-2004.html
    No-one scored better than random chance.
    It is clear from the above analysis that no matter what background or experience a participant brought to the test, it did not help him or her score better than anyone else. 49% accuracy is 49% accuracy.
    But the amount of improvement can be astounding!
    Unless you don't know if the fancy power cord is in use or not. Then it doesn't sound any different.
    Now it is an ABX test so it is not a 'normal' listening environment. But even so you'd expect an 'astonishing improvement' to be fairly easy to spot in pretty much any circumstances.
    But no-one seems to be capable of doing it.
    There was also a home test done on Hi-fi Wigwam back in about 2004 where the cables were sent to peoples' homes so they could swap about at their leisure. The cables were disguised so that it was not possible to tell the fancy leads from the standard ones.
    Unsurprisingly people claimed to hear clear differences even between identical power leads. Sadly the pages documenting this have been deleted from the site. I don't know why this would be, except perhaps because the site hosts many adverts for fancy power cables.
    if the people making the fancy power cables really have made amazing new discoveries in electrical theory how come they are not stepping forward for their Nobel prizes?
    There is an enormous credibility gap here people, and I for one am not going to attempt to jump it.
  8. #128
    I'm afraid his first sentence spoils it for me:
    It is just another manufacturer's attempt to convince you to buy their wares with some 'techno-babble' explanations. Some of what he writes is correct, some of it is vague, some contradictory and some of it is incorrect.
    Macca, when you get a chance, could you please have a go at posts #116 and #117? Ta
    Dominic, I'll get to your (quite excellent), rather lengthy post, after lunch. There is so much there you and I agree on!
  10. #130
    Maybe because the genuine improvements often experienced cannot be explained by basic electrical theory, and occur in other areas of audio not so far properly tested?
    Or perhaps sufficiently rigorous testing for the phenomenon [and the enormous amount of money required for that to happen] has not so far been carried out by the relevant authorities, in order for those claiming such improvements to be put forward for a Nobel prize?
