Results 1 to 5 of 5
Thread: CEC Belt drive CD transports are they that much better?
    Default CEC Belt drive CD transports are they that much better?
    A few weeks back I gave an old Marantz CD65II a new lease of life as a CD Transport.
    I first tried the CD65II in stock form taking the digital output via the RCA socket and it was quite uninspiring.
    After reading some of Mr Lampizators musings on improving the SPDIF digital output I took a look at the SPDIF output on the scope and the waveform did not look good.
    After some experiments with a small Lundahl digital signal transformer which was only marginally better I decided to try removing the transformer completely and take the SPDIF digital signal direct from the digital filter chip in the player and feed it via a small blocking capacitor and some miniature 75 ohm coax to a BNC socket on the rear panel.
    The result was very pleasing, the waveform now looked perfect on the scope. I decided I would improve the internal clock as well and fitted a TCXO now jitter clock module from Valab in Tiawan.
    The result was quite a revelation feeding the SPDIF input into my Devialet 440. I have never had a better sound from CD, in fact Iíd say itís got the edge over my ripped CDs played over Ethernet from Roon.
    Iím now considering if there is anything to be gained from improving the CD source even further by using a dedicated transport such as the CEC belt drive offerings.
    Would anyone who has a CEC transport care to comment on their experience with one of these, are they markedly better than using a CD player as a transport?
    I'm Simon.
    Any before and after scope shots?
    No.
    I'm Tom.
    I've been curious about the CEC transports as well would have loved to try one here, I was thinking about getting a dealer demo but then I realised that the UK list price is about two and a half times what you can get a new one for shipped from Japan (about £1100 landed from Japan with taxes vs £2600 - not including a decent step-down transformer, say £60). So I didn't follow through to organise ... I doubt I would pay the UK asking for one, so not fair to use the dealer's services.
    Actually, the price differential put me off getting one altogether - either you go grey market route and take a risk (what happens if some fault emerges) or you go dealer route and 1) feel ripped off or 2) get utterly hammered on resale.
    So I'm sticking with my Audio Note CDT2/II which is far from shabby, through a Mutec MC3+USB reclocker/USB interface that also gives me access via a spare Macbook to use streaming services or file-based replay.
    I'm colum.
    I noted this post regarding CEC Transports from another forum recently,
    The CEC transports sound good but if you drop the heavy puck when inserting or removing it you damage the spindle etc... So I have moved on to something less fragile which also sounds good.
    FYI
