Results 1 to 5 of 5
Thread: ohm output
    I'm gerald.
    Default ohm output
    My amps have 4 and 8 ohm outputs but I have just pick up a set of Dali Zensor3 speakers that are rated at 6 ohm.
    So any idea what ohm rating to use on my amps?
    Cheers Gerry
    I'm Dan.
    It's an equal mismatch either way, theoretically. The 6 ohms is nominal, and the impedance can go above that or dip below. There is no way to know without seeing the whole impedance curve of your speakers , so don't over think it.
    Try either tap and use whatever sounds best to you.
    You can try both, won't hurt anything but if the nominal impedance is 6 ohm it will dip lower than that at some frequencies so my guess would be 4 ohm tap will sound best.
    ......... so my guess would be 4 ohm tap will sound best.
    Plus one.
    Quote Originally Posted by Mike Reed View Post
    Plus one.
    5 Ohm?
