Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 66
Thread: Silver WBT or KLE Pure Harmony RCA Plugs
  1. #41
    The biggest problem is tone.
    I've solved your "TONE" problems, have a read of my old mate Jeff....
    http://jeffsplace.me/wordpress/
    Read his articles on Duelund. I actually have a little system dedicated to this wire.
    PRE
  2. #42
    I'm Brian.
    The biggest problem is tone. Whilst I've had IC's and Tonearms all wired with pure silver, it just didn't have the tone I was looking for. Cables are like tone control IMO and although the goal is for as little sonic imprint as possible, that can NEVER be achieved. Too many factors. It's incredibly unlikely that Silver is used in every single part of your systems input to speaker chain. Copper will be there, as will gold, lead and whatever else. As you found out Jimbo, usually a mixture of different materials is the best possible outcome.
    I have copper in my tonearm, silver from arm to Phonostage, copper from phonostage to pre, copper from pre to power amps, copper from power amps to speakers.
    Well done, Brian, seems you're not quite as retired as you'd have us believe
    Put me down for a loan when you start selling them.
    I've been making my own cables since 1992 Oliver , not quite ready to stop yet
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
  3. #43
    Bigman80 Guest
    Good on ya mate, glad you're back.
  4. #44
    Bigman80 Guest
    No lack of tone now mate, I'm very happy with where the sound is at. Which bit of that monsterous thread do you want me to read
  5. #45
    so ive heard.
    I'm Kevin.
    Interestingly enough these plugs will be going on the end of a cable Brian has recommended.
    I am going to try the one he recommends and something a bit more expensive for the pre to power connection.
    Kevin
  7. #47
    Bigman80 Guest
    Are you going for the WBT Kevin?
  8. #48
    All of it
    PRE
  9. #49
    Bigman80 Guest
    All of it
    I'll spend an hour on it later or tomorrow.
  10. #50
    As you say, the tarnish is a sulphide though my understanding is that it is still semi-conductive.
    Silver sulphide (Ag2S) has a resistivity of ~ 1.5 10-3Ohm.m, whereas silver oxide (Ag2O) is colourless and is an insulator, having a resistivity of ~ 10+9Ohm.m. Pure silver itself has resistivity of 1.6 10-8Ohm.m.
    Both the oxide and the sulphide are soft, so are easily 'cut through' by the wiping action of mating and de-mating the contacts.
