Hi, does anyone have a couple of small pieces of panzerholz sitting around. Please PM if you have and we can organise postage and cost etc.
Thanks
A
Thanks
A
How big do you need. Joe round the corner will have some from his deck
Just big enough to make a new SME tonearm mount and possibly a piece where I can make a 65mm circular tonearm mount.
Thanks Si.
I'll ask
I'm Macklow.
Hi - I've got several pieces - if you pm me precise dimensions inc thickness, I'll check my stock MH
Interesting stuff!!
Is this how they make those laminated beams you see in French hypermarket stores??
Not steel framed but laminated thick cross beams the size that normally is done in steel over here ?
Sorry to go off topic
Source
SW1X USB II
SW1X DAC III Special
Audiolab 6000 CDT transport
Amps
Speakers
BK Electronics XLS400FF Sub.
Cabling
Headphones
I need a small piece if anyone can help approx 124x119mm
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I'm still waiting
