Results 21 to 30 of 41
Thread: Audiophile urban myths and legends
  1. #21
    Might be dealing with the subconscious and not audio qualities
    Quote Originally Posted by nickbaba View Post
    On a related point, I read an interview with Tim de Paravicini recently where he said he had calculated that if we wish digital playback to equal analog reproduction we would have to use a resolution of 24 bit/400kHz.
    Here's what he says:
    I did my own summation—and this is from 20 years ago—that if we did 384kHz at 24-bit, we'll have a system that will resolve on a par with the best analog. That's the holy grail. And the problem, for the computer people, is having the balls to go that whole hog.
    Read more at https://www.stereophile.com/content/...cyFmhCsUJqk.99
    But he is making two false assumptions. 1) That we can hear sounds up to 45Khz which we can't and 2) that analogue can record and replay sounds at those frequencies which it can't.
    No wonder there are so many urban myths when you've got respected designers propagating them.
  3. #23
    CD players have moved on considerably since the '80s. I heard the early ones and they were dire in comparison to LPs. These days I think that both are equally good in their own ways; different in presentation, but just as good. (And just as amazing, in that a satisfying and emotionally involving sound is wrought from two seemingly clumsy replay technologies.)
    Never a total convert to CD (did't start until 2001), having valved CDPs has changed my aural perception somewhat. T de P's CDPs are valved, so there was probably a very good reason why he designed them thus. I don't have one, but they are well thought of, as is the relatively recent Rega one. There is something 'organic' in valved stuff which seems to benefit CD playback as far as analogue ears are concerned, at least.
  4. #24
    I had a buyer for my ( 1970’s )meridian M2’s whom I was talking to over a period of several days and I’d sent him all the reviews etc , photos of the the rear connections.
    Then he calls about an hour from collecting them saying “ Andy” “ where is the USB port “ ffs.
  5. #25
    Had a lot of usb ports in the 70's so a fair question
    Dunno about USB, there were a lot of hairy ports in the 70's
  7. #27
    Yuk
  8. #28
    I'm Nick.
    Well, he doesn't exactly claim people can 'hear' up to 45k, his exact words are "people can discern and detect sound up to 45kHz", which may or may not relate to hearing, in the sense that we can't hear below 20Hz but you sure can feel it in your body as a physical sensation on a big sound system.
    "First of all, the frequency response should extend from 3 Hz to 50 kHz, because we experience those frequency limits. We are able to detect audio up to 50 kHz. We don't hear it, but we experience it in other ways. I can give you tinnitus very quickly if I run an ultrasonic cleaner at 45 kHz. You are aware that it's on, and your ears ring when it's shut off. On the low end, we detect mechanical vibrations down to 3 Hz. When a marching band walks past you, you feel the drums in your stomach and bones. And that's all part of the sound...Digital should use a 400 kHz sampling rate and 24-bit words. Then it will satisfy the hearing mechanism and won't have a digital sound. Digital has a "sound" purely because it is based on lousy mathematics. The manufacturers presuppose too simplistic a view of our hearing mechanism."
    Tim de Paravicini, the Audio Interview: In Pursuit of Excellence
    by Bruce Bartlett
    http://www.ear-usa.com/tim-de-paravicini/
    Regarding the 2nd point, it's true that analog playback doesn't necessarily deal particularly well with high freqs, but I think the point he's making is that digital ignores everything above 20kHz (and below 20Hz) and supposes that's the limit of our hearing, whereas in the natural world there are overtones and resonances well above 20kHz that contribute to the perceived richness and complexity of a sound, and with well executed analog recording, at least, there's no artificial cut-off to the frequencies that are being captured.
  9. #29
    I agree that we can 'hear' through our skin and such but I reject the idea that the 20Hz cut off is what gives digital its sound since we can and do make digital recordings that cover up to twice that frequency bandwidth and no-one can distinguish between them and the same recording cut off at 22khz.
    I think he is starting from a false assumption, which is that analogue is what it really sounds like and digital is wrong whereas all the facts point to it being the other way around. Although I'd agree you can get products which sound 'digital', a sort of 'synthesised' character to the sound that is not entirely natural, this is not the case with all digital sources, indicating that the cause of it is not the fundamental nature of digital but some other factor of the design.
  10. #30
    I'm Neil.
    Well done Tim, not. He might be an amazing analogue designer, but has no idea about digital.
    When you break it down, vinyl has a maximum bit depth of around 12 bits (assuming best-case scenario of 70db dynamic range from vinyl). 16/44.1kHz is what is required to *perfectly reconstruct* a signal of 96db dynamic range, and from 20Hz to 20kHz.
