Results 1 to 5 of 5
Thread: Subwoofers and valve amps
    Default Subwoofers and valve amps
    A general enquiry.
    Subwoofers like REL benefit most by being fed a high output signal from the speaker terminals of the main amp in order to best match the character of the overall system.
    But, in my experience most valve based systems have that distinctive very low level hum in the main speakers if you place an ear up close to the drivers.
    So will installing a sub as described above amplify this hum to the point of distraction?
    SW1X USB I Signature
    SW1X DAC II Special
    Transcription Audio single ended, 211 triode, integrated.
    SW1X Open Baffle Speakers containing vintage alnico drivers - Grundig tweeters, Saba Greencone midrange and Altec VOTT 416 bass. All silver wired.
    I'm james.
    That hum should be mostly at 100Hz in the UK, so assuming most speakers have adequate output at that level it should make no difference. If it's 50Hz hum then that's a different matter, but that should only be from directly heated valve type circuits and there should be a humbucker to minimise it.
    Thanks James, part of the hum (50Hz) does come from the DC heated triodes, but that is well minimised with the humbucker. So its probably a residual 100Hz hum and I guess its possible to minimise that in the subwoofer by reducing the value of the sub crossover.
    SW1X DAC II Special
    I'm james.
    I'd say the amp should be designed not to have too much hum as designers surely assume that their amp will be used with full range speakers. Also a sub shouldn't exagerate the bass, just reinforce or extend it.
    My experience has been that I barely had it running, such that with only the sub running (at normal listening volume) it was barely audible, yet it still made a heck of a difference in my room!
    I
    With Hi Fi this has always been the way to set it up. With surround-sound one tends to be that bit more exaggerated with the bass.
    SW1X DAC II Special
