Results 1 to 10 of 17
Thread: Valve base down.. .
    Default Valve base down.. .
    What happens if a valve base goes down? I've got sound through both channels but noticed the one of my right EL34s wasn't glowing. Swapped the valves around. Same position not glowing. There was a bit of rustling on that side earlier so I re sat all valves. Could I have knocked a connection on the valve seat?? Easy enough to change? Ive git a few days off and was hoping fir a few listening sessions. ..Could I remove one of the left hand valves and use it at half output until i get it looked at or is there a risk of damage?
    I'll give it a go thanks. Typically I have new speakers to listen to.
    If I was to run the amp with one el34 inserted on each side, would there be risk of damage or does the output just half?
    Amp is a prima Luna Prologue 1 by the way
    Haha.. I think I'll leave it. Bloody valve amps....
    I wouldn't do it myself.
    This kind of situation is why I always have a spare (back-up) amplifier. A tiny SMSL is ideal.
    I've got the bottom off. Can't see anything out of sorts.
    The bottom of the pins are quite loose and rattley, is that normal??.
    I'm Duncan.
    If it's a push pull amp then both tubes are used at the same time in a "push pull" circuit. The channel switching happens before the signal gets to the power tubes.
    Confusion with this type of amp is that power can be cut in half by removing one of the two tubes, this is not how it works. The two tubes are a "team" and taking one out would make half of the output signal and the output transformer search for something to amplify, creating a horrid tone called "crossover distortion."
    Not a practice I would recommend.
    I'll take it to someone knowledgeable. Not sure tgere is anyone local, sadly as i think it woukd be a quick fix. Week off work and no music.
    Quote Originally Posted by Bourney View Post
    I'll gladly look at it for you but you would have to get it to me.
    Do you want a loaner?
    I have a Claymore MK2 amp sitting doing nothing, it's not perfect as there a channel imbalance at low volume but you're welcome to borrow it.
    Posted tomorrow you could have it by Thursday
