Originally Posted by
Simon_LDT
Yep, which is why ideally you need to set the Croft at unity gain (full volume I presume like most pre-amps). For me, I use a passive pre but still require volume to be on full for no attenuation. Then just set the trim levels for all speakers in the processor or player (depending on which if you're using for settings). That way whenever you're using the multichannel setup just turn volume to full on the stereo pre and levels will be set and only the processor will alter the volume, along with all other speaker connected. Best way to do it unless your pre has HT bypass.
