Looking for a new brush to use with my Moth record machine .
I have the Moth brush but the fibres are about one inch long and just does not seem to be cleaning the records as it used to and getting loads of static pops after a clean.
My home made fluid is
Isopropyl Alcohol, distilled water and Ilford ilfortol
I used to use dish washer rinse aid before going over to the Ilford and since swapping wetting agent static seems to be worse
Ratio is 80% water 20% ipa and 10ml of ilfotol in a one litre mix .
. So just wondering what you guys use ?
