I make 5ltr IPA/BP water and dishwasher rinse aid mixes at a time,it's stored in a cupboard and can last me some 3-4 years,I really couldn't be arsed having to make a mix every time I need to clean a few records and store it in a freezer.
Analogue. Basis signature 2200,Basis Vector 4.Koetsu Red,Koetsu SUT,NVO SPA 11.
Digital. Denon 2900,Jolida FX 11
Amp. Pathos Logos,Minidsp dirac 22A.
Speakers. Amphion Xenon.
Airlink CBS 2000 bps
As I only infrequently clean records now I keep a mix of about 1/4 litre in the fridge.
With Art du Son, as long as you don't have black or grey particles, it isn't biodegrading.
The white particles that you might see after a bit of storage are nothing to worry about.
The manufacturer recommends that you used mixed solution within a few months as it will biodegrade quicker than the concentrate.
Sonore Rendu - Cambridge Audio Edge W - Sonus Faber Venere 2.5
I always dilute a very small amount which I use up completely, usually 1 ml LAS to 50 ml water. Good for six records or so. One time I left the solution for a couple of days and it started to smell bad.
TT: none atm; Carts: Benz Micro Ace SL; Phono stage: Nuda dual mono
Digital: Rotel RCD-965BX, rDAC; Amp: Modwright KWI-200, Speakers: Dynaudio Special 25
I believe IPA can damage 78 records, or is not advised for use with 78 records.
I used Art Du Son for a while with a Moth machine and reckon it led to the demise of that said machine. Because the Art Du Son mixture is not volatile I reckon a residue collected in the machine and led to corrosion and the motor blowing.
I replaced the Moth with the Pro-Ject machine which was half the price and which I personally prefer - it's quieter and just as effective. Additionally, the supplied Pro-Ject "Wash It" solution seems excellent to me.
Cheers
Phil
I'm Brook.
I use L'art Du Son mixed with RO water & tend to do quite a few records over a 2 or 3 day period, so mix 1 litre at a time and haven't had a problem so far. I have read about this residue that some people claim to get if not rinsed off but I haven't found that myself, although once Hoovered & dried off on my VPI I do tend to do it again but this time without agitating the mix to a foam.
Anyone noticed its not the same formula that it was when it first came out?
I have been using the stuff for years without any problems. I suspect not all distilled waters are equal.
Sent from my SM-G935F using Tapatalk
I have always used purified water bought at a local pharmacy and have never had any issues.
