I'm Allen.
I'm Allen.
New Inverter microwave in the house
I can highly recommend a Panasonic Inverter combi Al. I've had mine about 15 years and it still works perfectly. I don't own a normal oven anymore and where the oven was now sits a freezer so the microwave combi is used all the time unless cooking on the induction hob
I don't think the Panasonics are the cheapest around but they are very good, mine has 1000w microwave, an oven that will go to 250c and a pretty decent grill as well. I think it was about £400 new
Bev
Just seen your post Al... oops
Is it a Panasonic ?
Bev
I'm Allen.
Hi Bev
The one I purchared is a Panasonic NN-CT555W
https://pricespy.co.uk/home-garden/w...hite--p3153322
Only warmed up some milk for my Barista poncey coffee
That's a bargain Al for a proper Inverter Panasonic
The Inverter bit means that when you, for example, set the microwave to 50% it actually heats at 50% power which is unlike most microwaves that actually use 100% power but simply switch in on and off.. but you probably knew that
I think you will love your new Panasonic Al
Bev
It's a handy feature, Bev, as with a microwave oven it's far better to heat food for longer on lower power, than shorter on a higher power, as the latter just dries things up. With ours, you can vary the wattage/power from 80 to 1000W, so you just set it to what you want before the cooking starts
Al, enjoy your new Pany!
I'm Allen.
