Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Optical or USB
    I'm Neil.
    The DAC I will be using will have fully galvanically isolated USB but reading more about it from the designer either USB or optical are fine and there is not much in it. Probably best try both and see which works best from MacBook laptop?
    I was more concerned about using a 5 meter length and how this would affect a USB cables performance ?
    No issues at all with a 5M length of USB cable. Lindy do properly specced ones for not much money.
    I'm inactive.
    I've always found USB much better than optical from my Mac Mini, not tried either over such a long run though.
    In the absence of USB I also prefer coax to optical (even using Fisual glass cable, which tends to be raved about...)
    I'm Neil.
    Quote Originally Posted by mikmas View Post
    What DAC / USB front end are you using?
    Chord Qutest. I would like DAVE!
    We'll have to do a bake off with my Bel Canto James, if nothing just for interest.
    Haha yes indeed. The Qutest will,have to be evaluated fully before I part with the cash.
    Surely optical, no?
    2TB Brennan fed through a Yamaha RN-803D network amp via toslink. The speakers are floor-standing Q Acoustics Concept 40s on spikes. Next up, CD player, turntable, possible sub.
    Quote Originally Posted by The Rogue View Post
    Surely optical, no?
    Its a bit of a fine line I think. Chords Qutest DAC is probably happy with either with only a marginal difference in sound but it does depend on the output from my MacBook Pro. Optical maybe be better?
    I'm Neil.
    With optical, the incoming clock signal needs to be extracted from the datastream, of which things like cleaning up jitter is DAC dependent, and the amount of jitter coming in is source dependent. With USB, the DAC clocks the data, making jitter issues moot.
