Page 24 of 25 FirstFirst ... 1422232425 LastLast
Results 231 to 240 of 246
Thread: Good analog and good digital converge?
  1. #231
    Quote Originally Posted by magiccarpetride View Post
    OK. So what matters (at all)?
    I already said what matters a few times. Basically none of the crap that you read about matters. You want good digital go and buy a high end Japanese CD player (or DAC, if you can find one, good luck with that, but they do exist) from about 1986 to 1999 and make sure the rest of your system is not set up to make recordings sound like 'live music' and you're golden.
    And if you do find a Jap DAC from that era and the bloke does not want the price of a decent used car for it, then be careful with the transport because that matters too. But not for the usually cited reasons.
    I can't believe you are a software engineer and you don't know how digital audio works. Wind up or what? Not that I care, my TV is broken so I'm at a loose end.
  2. #232
    I'm Alex.
    You were kind of starting to make some sense in the above post (if one were to squint real hard), until your last two sentences. That's when you totally disqualified yourself as someone who could talk legibly on the subject.
    Alex.
  3. #233
    I'm paul.
    Quote Originally Posted by mikmas View Post
    "His PhD investigated radial velocity using absorption spectroscopy and doppler spectroscopy of zodiacal light using a Fabry–Pérot interferometer based at the Teide Observatory in Tenerife. His research was initially supervised by Jim Ring,[2] Ken Reay[2] and in the latter stages by Michael Rowan-Robinson.[1] He graduated at the awards ceremony of Imperial College held in the Royal Albert Hall on 14 May 2008.[citation needed]"
    Wikipedia: Brian May biog.
    i think you've made your point
  4. #234
    Just been reading a show report from AXPONA in Chicago where one of the exhibitors set up a reference quality system with some mega bucks equipment. A very expensive high end digital system was blown away by tape! Yes an analogue R2R wiped the floor with the digital set up and gave all who listened to it everything you could wish for in sound reproduction.
    Maybe analogue and digital haven't converged yet! Apparently the R2R also bettered all the vinyl systems too.
  5. #235
    I am afraid Martin I think your digital experience is stuck in the dark ages.
  6. #236
    I'm Russell.
    Digital playback from CD’s, (and I assume audio files too?), is not perfect. It is not 100% accurate, and there is no second copy on a CD to refer to for error correction .
    Let me try to paint an analogy. You have a large block of wood, waist high and just as long, and it is cut into a bunch of peaks and valleys, like a Musical signal roughly. You measure it, it’s anchored to the ground so you can’t take it with you, so you make measurements of the peaks and valleys. You go back to your shop, you take 1x4’s and stack them against each other vertically. Trying to get as close to your measurements from the original. You can only be accurate every 3/4 inch, as that’s the thickness of the boards. So, you have built your copy, but the edges are all stepped up and down every 3/4 inch. What do you do? You take a jig saw and cut the leading edges off and make it smooth! Nice! Just like the original! But you take it to the original and place them against each other, and you find that all of your averaging has made a copy that is not accurate. The peaks and valleys are near the same place, but the edges are all different. It feels smooth to the touch! And if you couldn’t see them side by side, you’d swear they were identical. But, they are not. And of course the higher the resolution, if you went back with half inch boards it would be a little closer, and if you made it from eighth inch boards it would be even more accurate! But, on closer inspection, you still have tiny differences. There is no way to make an exact digital copy of an analog wave form. Out of wood, or out of electrons.
    Don’t get me wrong, you can get VARY close! And these errors in shape do not sound like distortions, they sound like music! They are smooth on the edges, music flows! It doesn’t create noise. But, it is still ever so slightly different from the original.
    Analog, I took a cardboard sheet and laid it up against the original wooden peaks and valleys and traced it, built the copy, and laid the cardboard on it, and traced it, and made an exact copy. I can take it back to the original and lay them up against each other and they will match! I’ve always thought of it as, analog is like looking in a mirror, while digital is like looking at a photograph. Maybe that’s an oversimplified view?
    Russell
  7. #237
    Bigman80 Guest
    Russell
    Russell, what a fantastic explanation. That's why analogue is better. I love it.
  8. #238
    I'm Alex.
    Russell
    You are describing the map, not the territory. Which is fine, of course, but as Korzybski famously said, "map is NOT the territory". I think all issues stem from the fact that we tend to forget this simple axiom.
    We don't really know what kind of information is being captured by the microphone membrane that vibrates and converts kinetic energy into electric energy. Yes, people will now chime in and call me clueless insisting that we know exactly what was being captured, but that is a naive oversimplification. All we know is that we get some sort of an electrical signal on the other end. That signal varies with time, and this variation is used to represent the information that is supposed to retell the story -- what happened back in 23rd March 1967 when the Beatles were recording "Getting Better", for example.
    Claiming that this electrical signal can be used with present technology to recreate the session is similar to claiming that, by measuring the kinetic energy produced by the virtuoso pianist, we can understand everything about that musician's talent.
    Folks, such naive approach to understanding what's going on around us in this amazing reality is called, in technical terms, 'reductionism'.
    Professing reductionism is not something that is hard to do, and is definitely not something to brag about. Any idiot can practice reductionism, and easily reduce any complex phenomenon to just a bunch of electrons and protons and neutrons buzzing around. So fcking what?
    If you have the courage to drop this oversimplification (or, as Lennon sang, "living is easy with eyes closed, misunderstanding all you see"), you have to accept the fact that the current state of technology is still in diapers, and that technology keeps growing up and is currently evolving at an impressive pace. So it would be absolutely moronic to lie back and complacently announce how we have solved all the issues surrounding capturing and reproducing sound.
    If I were to make a prediction, I'd say that we can expect some interesting breakthroughs to come at us from the field of machine learning and artificial intelligence. People are now working on such advanced tech called "smart dust" (IBM just unveiled fully functional computer the size of a grain of sand). Put that in your pipe and smoke it!
    Alex.
  9. #239
    Got a match? (..no not a bunch of 1001110010100100001010010100010)
  10. #240
    When I was being educated I studied physics and chemistry amongst the sciences and was fascinated by each subject. I was amazed at what mankind had learnt about the earth and the universe and everything in it and how it was applied to modern day living.
    But one thing I remember at the end of my science education was the fact that all I had just learnt may actually not be true. It is how we have labelled and come to understand what we know but that may not be actually how it is. It is a difficult concept but my lecturer actually went to great length to explain it was just how we had interpreted the world around us and how we tried to make things fit our conception of all about us.
    Many times conceptions have been torn up as the new science and knowledge has advanced.
    Once the world was considered to be flat! Go figure.
