Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Garrard 301 & 401 platters, interchangeable?
    I'm mark.
    Yes, nicked idea from Shindo. It cost's nowhere near £1K to produce a platter. A classic example of stupid prices being paid. I'll take my chances with this potential new product.
    There's a bearing there too, but I get the point
    I swapped 301 onto 401 today and it fitted, funny my memory said 'No'
    I'm Clive.
    The height of 301 and 401 differs by a few mm. You may need to shim the bearing to ensure the platter doesn't foul the chassis.
    I put a 401 bearing in my 301, the platter was extremely close to the chassis.
    Quote Originally Posted by Clive View Post
    Yep I also used to run the 401 bearing, I just used x3 1mm washers and it did the job perfectly. I'm not using the standard 301 bearing either. I've been through the standard 301 bearing, the Bastin modded 301 bearing, the 401 original bearing and now the SPH. The SPH is the best.
    Have you asked AudioGrail? I would have thought if anyone can answer your question it would be him.
    That was on my list of stuff to do!
    Quote Originally Posted by DiveDeepDog View Post
    Great! Thanks for trying it as well.
    PRE
    I'm Sien.
    ........... I'm not using the standard 301 bearing either. I've been through the standard 301 bearing, the Bastin modded 301 bearing, the 401 original bearing and now the SPH. The SPH is the best......
    Thanks for the compliments!
