Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: measuring Thiele-Small parameters - what am I missing?
    Thanks for the offer Geoff - much appreciated. I have the Thiele/Small parameters for some of the drivers from manufacturer's data sheets, but I'm not looking for data for any particular drivers, I'm trying to learn how to make measurements. Simply looking up specs from data sheets or other sources won't help me learn how to make measurements, so I'll have to get stuck in and get my hands dirty - best way to learn in my opinion
    Basically, I'm intrigued to learn what makes a good speaker sound good. Is it how expensive the drivers are? Is it the complexity and sophistication of the crossover? Is it the simplicity of the crossover? Is it a "perfect" driver/cabinet/vent Thiele/Small alignment? I'd like to do some playing about and find out what I can. My opinion (prejudice?) at present is that it's quite possible for speakers to be "all wrong" in terms of flatness of frequency response etc. yet still sound very nice. Do they sound better as refinements bring them closer to being "correct"? Let the research (or playing about ) commence.
    Very soon I will have in my possession (if the postman gets a move on) a DATS V2. I am hoping to use it to measure a pair of drivers I have recently acquired. One thing I will need to check though,
    and that is the required accuracy of the weight of the additional mass I will add. I have a roll of tape and I have weighed it on 2 different industrial machines, both giving 324 grams. Now, they cant
    measure fractions of a gram, will this be accurate enough?
    They swim... the mark of Satan is upon them. They must hang.
    FLAC / WDTV Live / Cambridge Audio / Tannoy VX12
    What mass are you thinking of adding and where?
    Hi. Is this aimed at me? I have seen people simply lay a chunky roll of tape on the woofer cone, centrally of course before performing the sweep.
    Quote Originally Posted by aquapiranha View Post
    I asked because I'm not sure what you have in mind. I don't know the function of the tape.
    Ah I see, sorry. I am as new to all of this as the next person! Once I have the TS parameters, I may need help with the box design...
    The mass needs to be between about 5g and 15g - much less than your roll of tape!
    You can look up the weight of coins and use them as accurate weights. For example a 20p weighs 5g and a 50p coin weighs 8g.
    The problem I had was fixing them to the cone. I tried double sided sticky tape but the coins can resonate at certain frequencies (you can hear them buzzing) and the effects show up on the impedance curve. Also, the sticky tape damaged the dust cap slightly when I peeled it off. Blu Tack wouldn't stick at all. If anybody knows a better method to add mass I would love to hear about it.
    Of course, you could use the test box method instead of added mass.
    Actually, you only need to add mass to calculate Vas. You can get the other parameters without the added mass.
    BTW, as an update to my original question, I'm now using ARTA software to do measurements and I'm making some progress. I'm working on a pair of speakers using small drivers which I know won't produce earth-shattering bass but I'm using them to get some practice mainly for crossover design.
    Laying a driver on its back will alter the resonance anyway, as the cone weight then bears fully on the suspension. So I'm not sure how an accurate reading can be done this way.
    Laying a driver on its back will alter the resonance anyway...
    Yes, I discovered that quite early in my experiments. With some drivers the shift in resonant frequency is quite considerable - with others, hardly any change.
    Yes, you couldn't just lay a driver on its back and place a weight on it anyway because the weight will bounce around.
    The roll of tape was just what I had seen online. I will have a good read of the manual to see if there is any advice or hints in there, thanks
