6 ohm speakers on 8/4 ohm amps ?
Just got a pair of Technics SB CH610's and they are 6 ohm not my usual thing but they were cheap enough LOL
[B]Class A , A,B Amplification[/B\]
Marantz PM4
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Speaker Cable , Digital Coax , Interconnects
QED Speaker Cable , Chord Coax Digital , Nakamichi Interconnect , Belkin Interconnect
Try both and see what you prefer. I think consensus is 4 on valve amps at least.
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Saw these B&W DM601 S1's cheap so had to have them fully working order and no pushed in tweeters...
Happy Listening
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Have you considered selling off a lot of your gear and getting some more expensive stuff? I used to be a bit of a collector like you (but not quite as much) and I did that, I haven't looked back since. You must be able to raise quite a lot of money from everything you've bought over the years.
If i the more expensive stuff was easy to find i would have it but its few and far between..
Very happy with what i have got....
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Just set up the Yamaha CR 820 and it has developed a fault with bass on full it seems to be rasping and popping the speaker same with the other speaker of the same pair so its an amp fault any thoughts on what i could be i cant get to the control as a board in the way of it...
Back out for a service "Again" when you have a lot of gear stuff like this happens makes you think twice and just own a little bit...
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Seems to be running well now...The joy of Vintage HI-FI
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Update with the Kefs upon testing last night the bass units are working well - ear to the tweeter and zilch on both speakers so i look inside they have a loose wire which can only mean its the tweeter never been connected to the switch for variable output connected the wire to it a viola one T15 lives and sounds superb just need to test the other and book them in for soldering of the wires not factory spec but one sounded really really good....
Watch this space....
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Both Tweeters tested and working fine and the speakers sound incredible i cannot wait to set them up properly...
Watch this space...
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
