Page 9 of 9 FirstFirst ... 789
Results 81 to 90 of 90
Thread: MacBook used in a Digital system
  1. #81
    I'm Neil.
    So what's your take on it then, Chris? Personally I've no doubt that 90% of the things people think matter in digital audio make no difference whatsoever. 'Jitter', 'Bit perfect', 'high resolution' and so on. The things that do matter, like the power supply regulation, no-one seems to be interested in.
    If your DAC uses a USB powered connection then this is a great piece of kit:
    http://www.aqvox.de/usb-power_en.html
    Makes the computer side a lot less relevant, as you get independent, galvanically isolated power for the USB device.
  2. #82
    I'm AMusicFanNotAnAudiophile.
    My take on it is that power is everything.
    Clean the mains up effectively and you'll get tangible gains in sound quality.
    The main culprit is switching noise from SMPS, and they're all pervasive.
    TVs, DVD/BDPs, central heating, fridges, washing machines - the list goes on and on - they all have SMPS, and they're all chucking switching noise onto the mains.
    Reduce all that switching noise, inaudible though it is, and your audio equipment will sound better.
    Chris
    Common sense isn't anymore!
  3. #83
    I'm Paul.
    I think that things like mains filters are ferrite beads are somewhat effective at stopping noise from the mains getting into your equipment, but are can be much more effective if you use them to stop noise generated by equipment getting onto the mains. This is why instead of using a large mains filter block I use single filters primarily on anything with a switchmode supply including the wifi router, which is close to the HIFI. Ferrite beads are on the fridge and CH boiler mains cables instead on the HIFI mains leads.
    ~Paul~
  4. #84
    Quote Originally Posted by Primalsea View Post
    That's what I did too.
    Ferrite clamps on everything but the audio system. The audio system doesn't need filtering because all the PSUs are linear, and don't exhibit the high frequency switching noise.
    Chris
  5. #85
    I'm Gary.
    I'd avoid these tbh.
    Made my servers sound worse and weren't even compatible with certain hard drives.
    Actually made the sound worse in my system! I use a fanless PC with solid state drive now, no filters, and my USB output has its own independent power supply, outside of the PC.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  6. #86
    That's external to the equipment, though. I'm talking about noise generated within the audio equipment itself, which is an entirely separate issue. I'm theorising that this is the reason that cd players with high quality power supplies outperform those with 'just adequate' supplies.
    The only smps I have that is active when the hi-fi is on is the router.
  7. #87
    I'm Neil.
    Yeah I agree with this, there's only a certain level of performance you're going to get with a couple of regulators feeding multiple chips.
    Also how the equipment deals with the noise coming in is important, and in digital, how RF return currents / ground bounce are controlled is paramount. As an example my DAC has balanced mains built in, 9x transformer windings feeding 9x supplies, and each of those supplies is zero feedback and uses 3 stage (passive) common mode filtering. Overkill? I don't think so...
  8. #88
    I'm Neil.
    What about all the RFI that rides on the mains?
  9. #89
    The SMPS noise is RFI, just with a limited range of frequencies.
    The local problem is the amplitude of it, and ferrite clamps improve the situation.
    Chris
  10. #90
    I'm Neil.
    Default MacBook used in a Digital system
    Ah now the increased amplitude of in home RFI vs. the AC lines makes sense to me. Thanks.
    Have been looking into lining my DAC and server with ERS paper from Stillpoints, anyone tried it?
