Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 90
Thread: MacBook used in a Digital system
    I'm Oliver.
    Having looked at Audirvana plus, I am pretty sure this will be the digital music management system I will use initially and output it via usb to a DAC.
    Now I wonder which DAC I am going to use?
    If it's not a Chord I'll be very surprised
    Analogue: Technics SP10 MK2 > Phonomac AT-1010 tonearm > Ortofon Kontrapunkt b > Wizard Jfet MC Valve Phonostage (Telefunken Valves)
    Digital: Firebottle modded Xiang Sheng DAC (Telefunken Valve)
    Amplification: Slagle AVC Passive Preamp & Firebottle Monoblocks (Telefunken Valves)
    Cables: Fisual S-Flex Speaker Cable & SPOTFIRE IC Cables Throughout
    Speakers: Pioneer CS-77A
    I'm Ian.
    I've recently moved from a Vortexbox to a Mac mini for digital stuff. I spent a while trying different software with the mini and ended up paying the fee for Audirvana. It has good management tools that make it easy to make the music server function the mini's main occupation but I presume you are not going to dedicate your mac to this job. Still, Audivarna is still a good sounding, easy to use music server. Only thing I miss from Vortexbox is integrated access to internet radio.
    Quote Originally Posted by ianlenco View Post
    First step is Audirvana output to a DAC then probably ipeng on iPad used in conjunction with music server, ripper, NAS device output to a DAC. This will give me Internet radio and should also up the SQ for file based audio compared to MacBook and Audirvana.
    I'm Neil.
    ...it won't up the SQ.
    If you are concerned about SQ, then what is way more important is that the DAC is galvanically isolated, and if you're using a USB to SPDIF converter, it's independently powered too. It doesn't matter whether I plug in my Macbook Pro, Media Server or ancient Netbook, it all sounds the same as it's all properly configured.
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
    DAC will be Chord Qutest which is galvanically isolated. I will use my Macbook pro either via USB or Toslink. Dont think either makes a difference unless I want to play DSD.
    I'm Neil.
    I have a feeling that USB would sound a tad more open than TOSLINK, only one way to find out. And yes itís the older Hugo and 2Qute that were not isolated, a bad move!
    Thought I would get the ball rolling with my digital system so downloaded Audirvana Trial version which will give me about 15 days free use of their latest version. Very easy indeed to set up on the Macbook and transferred all my iTunes library in an instant. Some of the features are quite sophisticated so I am exploring the different modes you can run this software in. DAC not arrived yet so listening via headphones straight off the Mac with Audirvana surpassing all the internal operating systems and optimising playback. Sounds superb, way better than iTunes, I may buy this software just for this reason alone!
    DAC arriving next week for full integration and assessment in my system via either Macbook USB or Optical (I will assess both) and then maybe via a music server /ripper/NAS. I am hoping the Macbook will suffice as it will be considerably cheaper.
    Audirvana certainly shows up the huge differences between MP3 and Redbook recordings. May try some 24bit and DSD stuff if I use a NAS. Must admit it is doing a wonderful job of civilising my digital material compared to what I have heard previously.
    If it sounds this good straight off the Macbook, whats it going to sound like through the Chord Qutest into my system! Bloody hell I might be a digital convert!
    I'm availableforweddingsAndBarmitzvas.
    Great stuff James, its good innit?
    All that and you still have the vinyl to enjoy too.
    You have PM by the way.
    I have hifi n stuff.
    The world is going to end, I know it
    Jimbo a digital convert?
