Results 21 to 30 of 37
Thread: Garrard 401 9" tonearm
  1. #21
    Quote Originally Posted by da2222 View Post
    Very useful and informative answers, many thanks to you all. The Mission tonearm is pretty tough to come by it appears but sounds like a bit of a bargain...
    One on eBay right now
    https://rover.ebay.com/rover/0/0/0?m...2F162931175160
  2. #22
    Of course, higher mass arm tubes can be bought for the Mission 774, but the standard article is very low mass, and will therefore only favour very high compliance cartridges, and that pretty much excludes most quality MCs.
    Not so.
    The built in fluid damping is there for use with low compliance cartridges. The fluid not only damps, but also provides a resisting load for the stylus to work against according to the viscosity and paddle chosen, thereby allowing the cantilever suspension to articulate properly and achieve the necessary excursion. The 774 works extremely well with low compliance MC's and Deccas. Without the damping in use it will of course cater to high compliance cartridges too, due to the low mass armtube.
  3. #23
    I'm Hugo.
    If the damping was applied to that extent and where it is most effective, I might agree with you. Where is Max Townshend when he is needed?
  4. #24
    I've been using Mission 774 tonearms for nearly forty years. Other arms have come and gone, but the Mission remains in use. It has given excellent results with a huge range of cartridges, with compliances ranging from 10cu to 50cu, damping applied as appropriate. The sound quality is always excellent.
    I still have three 774 arms.
  5. #25
    I'm inthescottishmafia.
    Have to agree, used mine with a range of MC’s and a few MM’s and it’s always sounded excellent.
    Hunter S Thompson
  6. #26
    They come up on Ebay fairly often. Maybe Geoff will sell you ne of his lol.
    Hunter S Thompson
  7. #27
    montesquieu Guest
    Huh. Can never have a tonearm thread here without the bloody Mission 774 mafia turning up in numbers ....
  8. #28
    Bigman80 Guest
    They are bloody good value though. An excellent arm.
  9. #29
    Tom (montesquieu) suggested the use of an Audio Technica AT 1005 arm. Mike Greenwood of this parish has one for sale should you be interested: http://theartofsound.net/forum/showt...57-AT-1005-arm.
    I'm slightly amused by the notion that the arm ought to be visually in keeping with the turntable. Aesthetics aside (which I can, and do, understand and appreciate), I would have thought it was more important to use an arm which brought out the best in the cartridge you are using, despite appearence.
    montesquieu Guest
    It's more than aesthetics I think. Idler turntables are of an era that had a sound, and for me I think it's important to follow the philosophy through which means low compliance, heavy arms, probably valve phonostages.
    Aside from that I'd take a fettled 1005 over most Rega derivatives any day at least for the sort of lower compliance cartridges I like to use. For my sort of cartridge preferences it probably also betters an SME 3009 SII Improved (though not necessarily an earlier one). The good news is it's also cheaper.
    The PU7 for all it's a modern arm also fits this 'retro' scenario in looks as well as function, in the form of higher mass and low compliance friendliness (as does my own Ikeda arm).
