Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 77
Thread: M2TECH Young DAC help!
  1. #41
    Not sure of the package size for the latest Linux, but it shouldn't need too much drive space.
  2. #42
    Bigman80 Guest
    I'll have a look Geoff.
  3. #43
    Bigman80 Guest
    Managed to get a hold of a banger laptop on loan. Installed the drivers and threw the cheapest USB cable in the world at it.
    It works and sounds better than it has any right to. Loses out a bit to the CDP in resolution and soundstage, probably due to the cable but, it's good enough for me to delve further into a good quality USB cable and see where that leaves me.
  4. #44
    Bigman80 Guest
    Oh, should also mention, that's an Avondale PSU which came with it. Only realised when I took it apart to fix the non working LED.
  5. #45
    Well done getting it sorted Oli. At least it gets you up and running.
  6. #46
    Bigman80 Guest
    Cheers Jim, it's a really good bit of kit this M2TECH! Love a good workaround. When life gives you lemons..........
  7. #47
    I'm Neil.
    Default M2TECH Young DAC help!
    I would get a Lindy cable, as they are guaranteed to be properly in spec and are very cheap compared to ‘audiophile’ cables.
    Also, is your computer set up for ASIO or WASAPI? This can make the differences that you are hearing with either one bringing more clarity and focus, and no resampling by Windows.
  8. #48
    Bigman80 Guest
    Thanks for the recommendation.
    How do I find out it's configuration. Obviously, the less processing before the dac is preferred
  9. #49
    I'm Neil.
    Best thing to do would be install Foobar2000 and follow this guide: http://newarchive.cambridgeaudio.com...1353494368.pdf
  10. #50
    I'm Neil.
    Any joy?
