Results 1 to 10 of 20
Thread: £300 to improve my system
    I'm Phil.
    Default £300 to improve my system
    Hi all,
    I have approx £300 available to improve my current set up...
    - Thorens TD160 , all stock with the exception of a hardwood plinth, thicker MDF baseboard and replacement RCA cables
    - Nagaoka Stilton MP11 boron cartridge
    - Rega Brio R
    - Rega RS1 speakers
    - Audiolab Q DAC (sources for this are laptop and chromecast audio)
    My first thoughts were either a new arm for the turntable, a new cart, new speakers or a record cleaning machine to improve upon the spin clean i currently use.
    For the speakers i need standmounts that can be used close to a rear wall.
    All suggestions and recommendations welcome!
    Phil
    I'm Neil.
    Sure, replace your Rega RS1s with a pair of Epos ES14.
    I'm tony.
    Airlink BMU.....It will give everything a lift.
    I'm Neil.
    Quote Originally Posted by wee tee cee View Post
    ...maybe, maybe not.
    I used one for years, a 2.5kVA one, but now I don't use any filtering, regen or balanced mains, just a big Olson mains block.
    I don't think you can really improve on that system with only £300.
    Although a proper record cleaning machine is a good idea, better than a spin-clean and a lot less mither
    I'm Phil.
    I guess I could sell the component being replaced to boost the budget somewhat. What do you think would be required to improve on it?
    I'm Andy.
    I would trade in or sell the TD160 and buy a better deck and arm with the proceeds plus your £300. Something like a Rock, Xerxes, pink, Alphason sonata, even a Mantra paired with a Rega RB250/300 will be a good step up.
    I'm Phil.
    The Thorens is actually the one thing i dont want to part with as it has sentimental value. I am happy to improve or upgrade it but will definitley be holding on to it.
    Quote Originally Posted by Scooby View Post
    Quote Originally Posted by MarginWalker View Post
    You could buy my little used M-Dac and sell the Q-Dac.
    I'm Andy.
    In that case I'd agree with Macca. I reckon you can get a different presentation by spending £300 but I doubt you'd hear £300 worth of improvement. A better cart will be limited by the arm. A better arm isn't really worth it on the 160. The amp is fine unless you're using more demanding speakers, but changing speakers to something better will only throw a greater light on the source.
