Page 1 of 11 123 ... LastLast
Results 1 to 10 of 102
Thread: I'd like to try valve
    Default I'd like to try valve
    Hi all,
    Im reasonably happy with my system but would like to try a Valve amp.
    I have no idea what to look for and hope members with experience of valve amps could suggest where to start.
    Looking for second hand but have no idea of cost or what would suit my system???
    My current lash up is
    Project 2xperience with recently purchased AT33ptg from a member
    Cyrus CD8se
    Rega Brio 2017
    TEAC X-3 Reel to Reel
    Dynaudio emit m20
    Cables Klotz - Audioquest Diamondback - QED XT40
    Any suggestions welcome
    Regards Steve...
    I'm Phil.
    why steve do you think a valve would be better ? would it not be worth going up the rega amp tree ?
    Eric Bibb
    Hi Phil
    I have listened to the Elex and the Elicit, they are very good amps indeed but have the same tonal qualities as the Brio just fuller and a little more resolving.
    I listened to a similar system to mine at a friends house but he was using a valve amp and i just preferred the sound, admittedly it was a a quite expensive valve amp made by EAR but it sounded fantastic, very different to the Brio and considering the rest of his system was so similar to mine.
    Regards Steve
    PS Not suggesting valve is better than all other amp types just want to try!!!
    Bigman80 Guest
    Don't start unless youre prepared to spend around £500 on a used unit. The cheap stuff will leave you feeling short-changed.
    Hi Oliver
    Thanks, my buget is around £1,000 to £1,200
    Regards Steve
    Bigman80 Guest
    Quote Originally Posted by STD305M View Post
    Hi Oliver
    Regards Steve
    Oooh, nice budget.
    No doubt there's something out there for that.
    I'm Shaun.
    Mega valve amp fan since 1995 I would advise caution in moving into a future of valves. I am blatantly biased by valves clear superiority in the voice and midband but I am also aware that pretty much like vinyl, they can be a pain in the arse. Like vinyl they are highly addictive especially when you get hooked on swapping and trying other types of glassware (tube rolling) and like vinyl the whole concept is bloody expensive. My one piece of advice based on experience would be to stay away from cheap Chinese junk but have a damn enjoyable future experimenting. All the best.
    Oooh, nice budget.
    There might be but not sure what YET
    Maybe try and borrow a valve amp first to try in your system before you buy?
    There must be something in the sound of valve or people wouldn't use them , Id just like to buy and try for myself and hopefully find the sound im looking for
    Thanks for the info and advise
    Regards Steve
