Results 1 to 6 of 6
Thread: Klimo Beorde Turntable Power Supply - Help!
    I'm Mauro.
    Default Klimo Beorde Turntable Power Supply - Help!
    Dear All,
    when I moved from Italy to UK I brought with me my favourite turntable Klimo Beorde.
    It remained in my storage for about one year.
    Now I moved it at my home, but I'm not able to find its external power supply anymore.
    I asked to the Italian distributor and he said that the power supply is available at a price of 500 euros shipment included.
    Honestly, it seems to me a bit too much for a basic power supply (it's just a little box with an on/off switch, the speed change is made moving the belt around the pulley).
    I'm wondering if there is any cheaper solution for powering the motor unit of the turntable.
    The motor input connector is not compliant to any standard known by me. (see pictures attached).
    Can anyone help me, please?
    Cheers.
    Mauro
    why is nothing ever simple?
    I'm Simon.
    Do you know what motor it is?
    I'm Robert.
    Is there no way you can locate the power supply ? I'd have to find it
    My System:
    CDP - Pioneer PD-91
    montesquieu Guest
    I would enquire over on the Lenco Heaven forum, there are more people over there who might be in a position to provide solid information about the turntable, its motor, voltages etc. There are plenty of turntable PSUs around (far more than there a types of motor) so the chances are there's something off the shelf that would do, but you more info about what you are looking for. I doubt many here will know this model.
    I'm Mauro.
    OK
    Many thanks Tom
    montesquieu Guest
    The other place to ask would be over on Vinyl Engine.
