Qobuz Sublime Plus streaming problems.
Is there anyone here using the Qobuz plugin on a Logitech Transporter with Qobuz Sublime plus?
I have been streaming for the last few months with Qobuz Sublime + without any problems, but in the last few days I cannot stream at 24bits 96Khz. There is constant breakup and the Transporter is continuously buffering the stream.
I have done all the usual things like re-booting the router, the server and the transporter. I have checked all the connections on the devices and the router. I checked the download speed was OK and I asked my ISP (Talk Talk) to also check for problems. But still I have a problem.
I have reported the problem to Qobuz, but I have not found them to be very helpful in the past.
I seem to have fixed the problem.
In the LMS settings I changed the streaming method from Direct to Proxied sreaming.
- You may not post replies
- You may not edit your posts
Forum Rules
