Page 14 of 19 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 182
Thread: Ker pow!!!
  1. #131
    I'm Dennis.
    According to Newell and Holland, distortion in the throat of compression drivers can be quite high due to the non linearity of the air under compression.
    Plasma drivers produce ozone.
  2. #132
    Care to comment on that, Andrew?
    Hello, are you still with us?
  3. #133
    My original comment was only intended as an observation that despite SS amps having (generally) a much wider bandwidth than valve amps they don't necessarily sound like they have more transient attack. Maybe some valve amps go up to 100kHz but I think my observation that most SS amps have a wider bandwidth than most valve amps is true.
    Sure, I'll buy that. However, in terms of the last bit, it goes back to my earlier point that you cannot judge how good *anything* is unless holding up the best versions of it as the example
  4. #134
    Hi Andrew,
    Thats fair enough, the last bit of my rantings implies that if a speaker impedance rises considerably across the audio frequency range, then by default because of the way each topolgy deals with those impedance/load changes, valve amps have the edge in supplying the correct power levels needed to maintain a [relatively] flat frequency response accross the varying impedance of the speaker, with frequency.
    There is no doubt that solid state designs can and do in many cases have a very wide' full power bandwidth, when connected to a fixed impedance/load, but as we know, a fixed load is not what we are dealing with where a conventional cone loudspeaker is concerned!
    A...
    Anyway, even if Anthony disagrees with the quote he clearly doesn't disagree with the sentiment expressed in my post - that valve amps don't sound like they lack transient attack, even if the specs might suggest otherwise.
    My post was actually a comment on Marco's idea that valve amps have a greater slew rate than SS amps because they have higher voltage power rails.
    This bit I don't understand at all:
    Wins the high frequency debate by default? I don't follow the argument
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
  5. #135
    Quote Originally Posted by anthonyTD View Post
    Indeed, and I think that's the key point here, and what should be considered
  6. #136
    I'm Neil.
    With Maggies, you probably need a goodly dose of both!
    At least 100W into 4 Ohms, but more importantly, high instantaneous current delivery, over 25A a channel should do it. Problem is you don’t get these measurements enough.
  7. #137
    I was trying to put it in a simpler way that most would get, but re-reading through that post, I can see that it could cause confusion amongst some here, so I will stand corrected if its required, hopefuly we will agree with this version, with a valve amp you have a measurable impedance at the speaker output, [unlike solid state, which is almost imeasurable with standard test equipment] A conventional push-pull valve amp, with very minimal feedback, will try to maintane a constant current at its output, hence when the impedance of a speaker rises [this will happen at higher' and lower frequencies, especialy when the frequencies aproach the natural resonance of the speaker drive unit] so will the voltage from the output transformer rise, in an attemp to maintane the same constant current to the load,ie; the loudspeaker! hopefuly that will make things a bit more clearer.
    Do loudspeakers require constant power across the bandwidth to maintain a flat frequency response? Or do they require constant voltage? I think you'll find that all reputable loudspeaker measurements are made with constant voltage drive, not constant power drive.
    Nikola Tesla
    Matthew 5:10
  8. #138
    I should also take this opertunety [while its fresh in my mind] to stress why when it comes to wide power bandwidth [where valve amps are concerned] a good quality output transformer, with a decent amount of iron is necessary!
    Nikola Tesla
    Matthew 5:10
  9. #139
    And that's the bit that costs the real money. You can see the bind that 'affordable.' valve-amp manufacturers are in. The 30 watt valve amp with proper traffos and a price tag of several thousand vs the 30 watt competition with cheap traffos and a price tag of a few hundred. And the audible difference is quite shocking but most punters don't know what a transformer is and even fewer know how much it matters. That makes marketing the good amp very difficult unless you are a well-known brand already.
  10. #140
    Exactly!
    The speaker impedance at resonance can often be double, even tripple that of the nominal 4, 8, 16 ohms, So' if the output transformer doesent have enough inductance at these frequencies, it can saturate at realistic power levels.This is why output transformer design is often refered to as a dying Art.
    Nikola Tesla
    Matthew 5:10
