Results 1 to 10 of 12
Thread: Beware, cheap banana plugs
    I'm Alex.
    Default Beware, cheap banana plugs
    I have some with the free to rotate springy bit shown in the video. They were OK when new, but soon started to produce an intermittent connection. At first thought it was was one of my connections, but no, it's the plug.
    https://www.youtube.com/watch?v=PcPNN7HxzGk
    Spendorman
    Yes. They are not too durable.
    I've also had problems with those that have a spring on one side, with the spring coming loose. Like these:
    I try to stick with Nordost style 'Z' plug types for my main cables. These:
    I'm Gary.
    +1 for Z or BFA same plug different name.
    I'm Peter.
    Ooh, this is well timed. I've been thinking about changing my banana plugs. i do have the cheap plastic ones. Now I know what to look for to replace them with something better. Thanks
    Peter
    I'm Gary.
    Buy mine on eBay, right angle ones where possible, I think they put less strain on connection to amps, speakers etc.
    Quote Originally Posted by symon View Post
    I'm Alex.
    These Belling Lee plugs used to be supplied with Quad amplifiers, in decades of use, never had a problem
    Speaker-Plugs-4Mm-Belling-Lee-L378A4-Red-blk- by A60man, on Flickr
    Spendorman
    I'm My.
    I use the Nakamichi plugs, I presume they are the same as the z plugs. However, I'm not convinced that they are the real McCoy and wasn't when they were delivered!
    I'm Allen.
    Z plugs for me
    I'm Phil.
    i use wbt or these have been good
    https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    they really grip
    Eric Bibb
    Personally, I wouldn't use anything that doesn't feature either solid-copper or silver conductors. I don't do plated brass, as to my ears, it's distinctly inferior. Therefore, I never have issues with cheap banana plugs - or cheap any plugs for that matter, as I don't buy them.
