I don't really know anything about this except that it is a diy job, it has a very heavy chunky walwart PSU (French plug) and it takes an ECC83 valve. The attenuator is notched but I think it is a standard potentiometer rather than a stepped one. There is a 2 way switch at the front to change the gain, I'm not sure if that is variable gain or feedback. I'd like to think it's not a switched mode PSU given the size and weight but again have no idea, it has a switch that lights up when it's switched on.
I've used it on and off for several years both as a pre amp in my second system and a "buffer" in my main and headphone systems by setting the gain at unity. It gives the music a definite valve flavour. The gain switch seems to make it sound more full bodied and weighty at the high setting but that could just be me not accurately changing the volume level accurately to compensate. At the high setting the unity gain is around 10 o'clock whereas it's nearer 12 at the low setting, so it's quite high gain (as you'd expect with a 12AX7).
No idea what it's worth, so say £35 plus postage with a Chinese valve (not the Mazda valve shown in the photos).
