Results 1 to 7 of 7
Thread: WTD: NAD preamp
    I'm Roger.
    Default WTD: NAD preamp
    Has anyone got a NAD pre amp available? Fairly unfussy, but must have a phono stage.
    I'm Graham.
    Default NAD PP2
    I have a NAD PP2 Phono preamp which you may have for £50.00 plus £5.00 P&P if that's any help.
    GrahamS - It's not what you hear that counts, it's what you think you hear........
    Present Kit: NAD 326BEE, NAD C515BEE CD player, JVC QL-7 DD turntable, JVC Tonearm, Shure M97Ve, Audio Technica AT95EX, Pickering V15, JVC Z1E, Wharfedale Diamond 230s, Visual Rio interconnects and My Ears.
    I'm Alex.
    I guess you know that many NAD integrated amps can be used as a pre. I sometimes use a 3130 to drive various power amps.
    Spendorman
    I'm Roger.
    Quote Originally Posted by GrahamS View Post
    Thanks, but it's the entire pre I'm after, not just the phono pre.
    Quote Originally Posted by spendorman View Post
    I do, and I'm using a C320BEE at the moment for exactly that, but fancied a dedicated pre so I could use the integrated elsewhere
    I'm Alex.
    I remember reading, many years ago, that a particular NAD pre-amp was electrically exactly the same as the pre part of one of their integrateds.
    Spendorman
    That's the 1020 I think, it's just the pre-amp part of the 3020. They're pretty old now.
    I'm Graham.
    My NAD370 had distinctly separate boards for the left and the right preamp channels and a combined power amp stage.
