Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: I want to use my headphones-help please!
    I'm gone.
    Poo. That is crap service.
    I've a SMSL SD793ii you can borrow, if you like.
    Small box but powerful output.
    It's only got digital inputs, though - RCA and TOSLINK
    https://www.amazon.co.uk/SD793-II-PC...s=smsl+sd793ii
    Thank you for your kind offer Jerry, which may be the way to go for me, but since I've learned what the Myryad amp can do (four inputs, enabling connection of CD, Phono, etc and use as a preamp too), I'm going to spend a little time trying to source one first.
    My Audion Silver Night is not an integrated, but a single input power amp with a volume control. This means plugging and unplugging leads each time I want to change source, and the Myryad would enable me to select sources without having to do this. My only concern is whether chucking the Myryad into the audio chain would degrade the sound, but my cloth ears probably wouldn't notice.
    I have a question for you though. My CD player has a digital out that looks like a single RCA socket-does a single phono lead go from this to the one on your DAC?
    You will have guessed by now that I'm a complete numpty with things technical, and if you can spot any holes in my ideas I would welcome your wise words.
    thats a spdif digial coaxial 75 ohm rca cable it takes.. https://www.google.co.uk/search?q=di...43294381637092
    I'm gone.
    Looking at the User Manual for your Densen CD player online, I think it is a BNC digital output socket, for which you will need a small adapter to use with a standard RCA phono cable.
    Happily, I can supply one of those.
    But if you now fancy full multi-input pre-amp functionality, then you will need to look elsewhere.
    Thank you guys. I thinks it's time I dragged my luddite ass into the 21st century, so I would like to take you up on your offer to loan me your DAC, Jerry.
    I may then be able to get into some streaming too, but my brain can only handle learning one thing per day, and I've used up today's quota reading your posts
    I'm gone.
    No problem, Steve.
    I've had a clearout of my PM box so I no longer have your name & address.
    Please remind me by PM!
