Results 1 to 10 of 15
Thread: Another DIY carbon fiber tonearm
    Default Another DIY carbon fiber tonearm
    Thanks to Qwin for being the first (that I know of) to post his DIY carbon fiber tonearm for the 1200. I just completed this on my 1200 M3D and love it.
    I also used KAB superflex wire and ran it from the cartridge straight to RCA jacks I put on one of the hinge plates. While I had it apart I put a blue LED in place of the white pop up light.
    I built an external PSU (from a thread here) a while back. Sorbothane feet and a KAB fluid damper are also being used.
    I had the fluid damper before the DIY tonearm and left it on mainly for comparing the sound, I may take it off later just to see.
    I'm Stuart.
    It looks really something, congratulations!
    I look forward to your opinion of the sound.
    I'm phil.
    I agree if looks are anything to go this is going to be good,
    Modded td160 super Thorens ol encounter arm hana sl cart, angle audio studio pro mc virtual battery phono amp with separate psi, Onix pre and mono amps, Onix CD player, Onix BWD and soap tuner. B&W dm2 speakers or super pencil 12 speakers, atlas cables, seperate mains power supply with earth spike.
    I'm Ken.
    Nice work David
    I'm Artur.
    Congratulations David
    I'm waiting at your opinion of the sound.
    Well so far the channel balance seems to be better, not sure why. The clarity is definitely better. I really need to listen to a lot of records and figure it out
    I'm Allen.
    Hi David
    Looks very good , What did you use for the cart end of the arm tube and cart mount / finger lift ? is it custom made or something purchased on line ?
    Hi David
    It is a cheap one I purchased online. I removed the connecting pins from it so I could run the wire straight through to the cartridge.
    I'm Ken.
    Al - The head shell off the Linn AV-X is quite nice and easy to adapt to fit, I used one on my carbon arm.
    Pictured here: http://www.jkwynn.co.uk/TechArm_HTML/TechArm_02.html
    Quote Originally Posted by cyto View Post
    Here are a couple of pix. I went with a cheap one because I didn't want connectors, just a flat surface to attach the cartridge to. I glued it into the carbon fiber tube with JB weld.
