Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: Moth RCM
    I'm Lee.
    Have you had a look at the new Degritter thats due out in May 2018, its an ultrasonic cleaner, looks quite good but Ive not seen one yet as they are still in beta testing
    http://degritter.com/
    Vinyl rig 1 - NAS Spacedeck / Jelco 750D / EAR 834P modified / Denon DL 103. Vinyl rig 2 - Lenco GL75 c/w original arm and Shure M75ED MM cart / trichord Diablo with NCPSU. Amplifiers - Audio Note Empress Silver / Hattor Passive Pre. Digital - Mac Mini / Lampizator Atlantic Plus tube rectified Dac / Linear PSU / Hummingboard Network audio adaptor. Speakers - Horns.pl Mummy's. Cables are Audio Note / Albedo / Duelund WE16GA Speaker wire. Power conditioner is a Gigawatt PC2 EVO
    I'm John.
    Quote Originally Posted by Lee Henley View Post
    Looks interesting Lee. Will check it out. Thanks.
    Record player, CD spinner and speakers for listening.
    I'm Mel.
    There was something like this at the Bristol show and it appeared to clean 3 lp's at ounce - wasn't working just on static display.
    Be aware that ultrasonic machines are abrasive in action and so it would be wise to only buy a unit designed for gentle vinyl work !
    Mel
    I'm I'mteachingmarcotheartofpishanto.
    Quote Originally Posted by Cycleallday View Post
    Mel
    I think you will find it makes a Loricraft look cheap
    Music , fills the gaps between silence !
    TAT Sale post Leader " Marcos Mentor "
    Also a pishanto specialist confirmed by Head Daftee
    Real name " Allen " or "Zoomer Nut”, “Numpty Napper”.
    ±± KEEP IT REEL
    Is that the machine I got a price for in another RCM thread ? It is undergoing trials before going to market ?
    If so, you could buy two Loricrafts for the price..
    Yes Dave I think it is
    ±± KEEP IT REEL
    the way they talked it was supposed to be a lower priced model. dont see a good reason for a machine to be any more than a grand or so. moths are great value as they go for ever. i dont mind wearing ear plugs
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/EMOTIVA XPS1/12V BATTERY - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP\WE TUBED - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, SPOTIFY - SMSL M6 MINIDAC - RPI/AUDIOPHONICS/5V BATTERY - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm Lee.
    The guy had an open budget so felt it fair to put up a reasonable priced machine that looks to fit the criteria in the orgininal request, according to the industry expert Michael Fremer that cavitation based machines are the best method for cleaning vinyl records and I don’t think IMO that these can be dismissed when considering a future RCM
    I'm Lee.
    Mel
    A friend of mine who lives down south uses the Audiodesk ultrasonic machine for cleaning Records, also has the VPI machine, he’s had it since it came out 5 years ago and to date has reported no issues with any abrasive action damaging the records, he also claimed that the VPI now makes a nice dust collector in the corner of the room
    Not quite sure how these work, but I think the record revolves in a tank of fluid, which, presumably, is ditched after a certain number. If so, that doesn't sound too good to me.
    Do they vacuum dry (or even blow-dry) the record so that it's ready for the inner? Can't see how, with part of the record immersed. Whereas I'm sure the ultrasonic method is superlative, it seems pointless if you're going to lose the benefits of a common or garden RCM.
