Results 1 to 5 of 5
Thread: Acoustic panels
    I'm Stephen.
    Default Acoustic panels
    A pair of home made acoustic panels - approx 4' x 2' x 2.5".
    Used to tame the reflections behind my dipoles but other half preferred a patterned cloth rather than plain calico. So hardly used.
    Incorporates 2" thick insulation with a 10mm gap behind.
    Light, easy to hang and do the job.
    £44 the pair.
    You can see one behind the 'stat . . .
    [IMG][/IMG]
    Current kit :
    Music library (FLAC) on IMac or streamed via Qobuz. Fed wirelessly to Raspberry Pi / Allo Digione and into Lyngdorf digital amplification. This handles room correction and drives a pair of Quad 2905 electrostatics.
    they look well made. you should state if they are pick up only
    Way too far for me to pick up, but if you don't mind saying, what insulation do they contain?
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
    This is the best stuff for first reflection and mid acoustic insulation
    https://www.travisperkins.co.uk/Rock...E&gclsrc=aw.ds
    Need to be covered in fabric though for some reflection.
    I'm Stephen.
    As Jimbo says, R45 rockwool (50mm). Cover in plain calico.
    Sadly they are a bit awkward tp post but i do get to Basingstoke and Poole areas now and again . . .
    Current kit :
