Results 1 to 10 of 12
Thread: BNC Connector
    Default BNC Connector
    I plan to make up a short cable to replace the RCA to RCA cable I am currently using to connect my Allo Digione to my DAC. I have the cable and a good quality RCA phono plug but need a BNC connector. Where can I get a good quality BNC connector that will allow me to use a fairly thin coaxial cable. I would prefer one that doesn't require special crimping tools.
    Alternatively, any ideas on where I can get a short ready made BNC to RCA cable. Ideally, 50cm or shorter, although it has to be very flexible so that it does not stress the sockets at each end.
    Thanks
    Geoff
    I'm AMusicFanNotAnAudiophile.
    Chris
    Common sense isn't anymore!
    I'm Deleted.
    Or eBay. You need 50 Ohm ones (I think - doubting myself now).
    Account Deleted
    I'm Gary.
    I wouldn't think you will find any difference between an RCA-RCA or RCA-BNC in performance terms, I didn't notice any.
    If you are just making up a short lead I would have thought good RCA plugs at both ends would be OK.
    Thanks
    Geoff
    75 ohms
    Chris
    Why don't you just get an RCA to BNC adaptor? A few pence from Maplin
    There are gold plated ones as well
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    Quote Originally Posted by ovlov854 View Post
    See no point in adding an extra link in the chain if I am making a cable from scratch. The BNC socket on the Digione is much more securely mounted and seems to offer a more rigid (i.e. locking) connection.
    Geoff
    I'm Simon.
    RS will have BNC solder/clamp plugs to suit. Probably for either RG59 type cable about 5mm diameter or RG174 roughly 3mm.
    Sent from my SM-G930F using Tapatalk
    Source: Thorens TD124 Rega RB300, Sumiko bluepoint No2., Cambridge Audio D500 Special Edition CDP, Squeeze box Touch, PC with Trends Audio USB Audio DAC UD-10 Amplification: Croft Micro 25 basic pre, Leak Stereo 20, Trends Audio Class T TA-10, Fisher X100-A Speakers:Impulse H6 Interconnects: Handmade silver and TNT audio CAT5 speaker cables
    Thanks for all the suggestions. I have just bought this on Amazon UK https://www.amazon.co.uk/gp/product/...I2R2YFK8&psc=1
    The same cable is being sold by some retailers for much more so this seems a real bargain. The right angle connection is perfect for my needs so it's just a case of cutting it to length and soldering on a good rca plug. So cheap I'm not worried if it doesn't work out.
    Geoff
    'Cos it will sound cack
    Adaptors of any kind, on a signal lead (especially such a critical one as this), are about the worst possible bottleneck you can introduce into a system! Avoid at all costs.
    However, Geoff, you'll only get the full benefits of BNC, if you do it throughout, by replacing the RCA socket on your Allo Digione or DAC (whichever item currently isn't fitted with a BNC socket), and then fit a BNC plug at both ends of your respective cable.
    That's the only way of doing the job properly
