However... To do it RIGHT, as you say (and as Andrew has designed in what looks to be a superb unit), the chosen SUTs must be hardwired into the circuit of the partnering phono stage, to avoid the sonically detrimental effect of raised capacitance, when SUTs are employed externally inside a separate box, via the use of interconnecting cables, especially when those cables are any longer than 0.5m - and even at such short lengths, it markedly alters the sound for the worse.
Also, if the SUTs employed are correctly located within the circuit of the partnering phono stage, any hum will be minimal and well below the threshold of audibility, when a music signal is present. Undoubtedly, it's a rather elegant and effective way of amplifying that signal.
Trouble with that is (as we live in an imperfect world), you lose the flexibility of trying different SUTs with your chosen cartridge, as you're stuck with whatever the manufacturer has fitted, and so whether or not those will be an ideal match sonically and/or electrically is largely a matter of luck, especially when it comes to the former. The latter can be achieved by matching them to the spec of the cartridge, but even then there is still an element of trial and error needed if one wishes to get the absolute best results.
One has to consider this lack of flexibility carefully, because I've found that the key to achieving true synergy between an SUT and its partnering cartridge, electrical parameters aside, is to successfully
marry their respective sonic signatures, as experience has shown that all SUTs have their own unique 'sound', such is the nature of transformers, as indeed do all MC cartridges. Therefore, for said 'musical magic' to occur, one has to achieve the best balance of traits between both - and the only way to do that is to experiment! Something you can't do if the SUTs are fixed into a circuit...
And that is the conundrum of using SUTs:
Unless you've been able to experiment with different ones, in order to find that 'magical combo', and then hardwire the chosen SUTs into your existing phono stage, which is both difficult and likely impractical to do, you'll never know if there's some other SUTs out there (often rare vintage ones, originally used in microphones), which could add something really special to the reproduction of your favourite music.
With head amps (which fundamentally sound different from SUTs) there exists less variables, and therefore the likelihood of missing out on that 'magical combo' is lessened, although that's not to say that head amps don't sound different, they do, just not to the same degree (IME) as transformers. Therefore, if you like what they do, sonically, in comparison with SUTs and use a really good one, designed to match the electrical parameters of your chosen cartridge, the results can also be sublime.
This is especially true when used in conjunction with a top-notch valve MM phono stage, as to my ears, when the right combinations are achieved, there is a synergy between head amps and valves that is as musically beguiling (although in a different way), as when the same has been achieved with an MC cartridge and SUT - and which cannot be matched when head amps are combined with solid-state MM phono stages.
Furthermore (returning to SUTs), sometimes, depending on what cartridge is used, one can over-egg the pudding, in terms of the 'mellifluous effect' achieved when combining valves and SUTs, with everything sounding a trifle 'too nice'. This is far from automatic, of course, especially if the partnership is right, but I've heard it happen all too often, and I'm not into that sort of 'airy-fairy' sound, which ultimately lacks drive and 'punch', and only suits certain types of music.
If, like me, you have wide and varied tastes in music (and a sizeable collection of such on vinyl), and so one minute can be listening to AC/DC, and the next, some classical Sonatas or solo piano, that simply won't do, as you can start finding that the music you play is being dictated by what sounds best with your SUT...
