Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 103
Thread: lap top v raspberry pi
    Quote Originally Posted by WAD62 View Post
    OK point taken...I'll bow to your experience RE. USB
    I'd also second your SPDIF board suggestion, the best I've heard from a pi was via a hifiberry digi+ pro SPDIF board with isolation...
    I have a Hifiberry Digi+ and it is very good. However, the Allo Digione is far better. Incredible detail and clarity, although several times the price.
    Geoff
    I'm Will.
    Quote Originally Posted by wee tee cee View Post
    Dac is the one built into my TQ claymore that i use as a pre.
    Best dac ive ever tried ,so really want to utilise it with a pi if possible.
    The question regards memory stick with pi-i would rather use solid state than a spinning drive if possible.
    Dont have a clue regards operating systems tbh....or computers in general.
    You can use a local HD, USB stick, or NAS for your files...
    However, although the setup of a pi is much easier than it used to be, you'll still need some basic computer skills...or a mate who has
    Cheers, Will
    I'm tony.
    Will,
    That is where i fall down but have some help available-just wondered if those in the know reckon the pi as a dedicated server had the edge sonically.
    Im not averse to going battery/linear supply if it reaps rewards.
    The lap top route has served me well for years, just trying to up the game on a budget if possible.
    ive got a pi with battery and laptop. i prefer the laptop, and rarely use the pi these days, but there isnt much in it imv sonically.. go with what your comfortable with
    I'm Will.
    Will,
    I use a pi3 as my LMS server, and a couple of pi's with HAT DACs in secondary systems...if you want absolute SQ from the pi then it seems to me that the ALLO SPDIF is the way to go, as mentioned by the others. (I may have to check that out myself )
    FWIW I use iFi iPSUs with my pi/HAT DACs (Audiphonics, and IQaudio), and there's an improvement, but as they are secondary systems I'm not going to go any further...let your help have a look at these options...I'd recommend ethernet connectivity for simplicity, and resilience
    https://sites.google.com/site/picore.../home/how-to-1
    https://volumio.org/
    http://moodeaudio.org/
    I use picoreplayer, as it integrates into my squeezebox world, I'm still using a SBTouch, Boom, and classic too...
    Cheers, Will
    No problem with memory sticks if formatted properly. Latest Pis have 4 usb ports so you can use more than one usb stick but heat dissipation may be a problem. I have stopped using my San Disk Ultra for continuous use because it runs too hot.
    Geoff
    Agreed. Ethernet gives much better results. You may need to buy a ethernet over mains kit for this depending on the location of your router.
    Geoff
    I'm tony.
    Grant knows me....the computer sides of audio just aint my bag-the lap top/usb suits me fine....just wondered!
    Greatly appreciate the contributions folks-just too far out my comfort zone!!
    If my good lady cant turn on the hi fi and play tunes when im out at work without a lengthy telephone call then it aint happening.
    Thanks folks...
    I have two you could try, one is a Pi with Allo.com Boss DAC with rca out, and I also have an Allo.com Sparky with Piano 2.1 DAC and Kali Reclocker ( broken RCA on one output needs fixing ).
    I'm pretty sure the Pi/Boss DAC combo is as good if not better than the TQ DAC, if I remember right
    I could have that all set up ready to run for you to plug in and play with only the drive with your files needing to be linked to it.
    Let me know.
    montesquieu Guest
    Quote Originally Posted by Shovel_Knight View Post
    In short: the USB output on the Pi is notoriously flaky. A laptop is probably much better for audio applications.
    This is my experience too.
