Results 1 to 10 of 20
Thread: tannoy eatons
    I'm Phil.
    Default tannoy eatons
    so many years ago in west norwood we had tannoy speakers instead of church bells as they were based there in south london i think
    never had a pair of tannoy in my system but by chance i have some eatons . now also had some frugalhorns for past few weeks which quite frankly have been entrancing . i fact they rather spoilt the arrival of some speakers i had ordered because they were so different [harbs shl5plus]
    so these are the NEW legacy range from tannoy and retail at 4.5k i think .
    they go deeeeeeeep man for such a little speaker , enough to be worried about the neighbour when playing organ music . so will be listening over next few days and considering i normally walk out of most tannoy rooms as they are too forward for me these classic series are most interesting
    P1050246 by , on Flickr
    P1050245 by , on Flickr
    P1050247 by , on Flickr
    Last edited by hifinutt; 20-02-2018 at 22:16. Reason: clarify these are not past masters
    1]bel canto pre 3 vbs /MSB s200 , / Marantz sa8005/ bel canto fm1
    sonos, . tannoy eaton legacy 2]velleman 8020 pre , firebottle mono`s onkyo sacd bel canto 3.5vbss and RFC impulse ta`us , track audio stands
    I'm Alex.
    They look in very nice condition.
    Be interesting to hear how you get on with them.
    I have a pair of Devon's, but usually use Rogers LS3/6 (with Export Monitor bass units), in preference.
    Spendorman
    Quote Originally Posted by spendorman View Post
    Not surprising I guess. They look like the new 'Legacy' Eatons to me. The design is not related to the seventies HPD Eatons.
    I'm Alex.
    I was fooled! the grille cloth and badges look similar to my 70's Devons. I should have noticed the Bi Wire facility!
    Spendorman
    If the grille was off in the photo, no doubt you'd see a 'tulip waveguide' tweeter staring at you from the centre of the driver.
    I'm Phil.
    yes they are a new pair on demo
    what is the earth binding post for on the back ?
    good write up here
    https://www.avforums.com/review/tann...r-review.13980
    Quote Originally Posted by hifinutt View Post
    To earth the metalwork of the driver I expect. The manual should tell you, if you have it. I suspect it is unlikely that the earth needs to be used.
    I'm charming.
    Have never used it on my DC10Ts.
    I'm Phil.
    ah i don`t have it.
    not to worry . using them with a 20 year old philipps amp and sound very balanced indeed. not even a twinge of brightness . playing an old recording of incantations [mike oldfield] which can sound sharp on some systems but its absolutely fine
    later on in week will put them with the thrax valve integrated
    http://www.pinkfishmedia.net/forum/t...d-amps.212436/
    I'm Edward.
    Ha I was confused for a second as well as they looked a bit like my Eatons and I thought someone had done some cosmetic improvement. Then saw the biwire links.
    It would be interesting to hear the old and new side by side. Pity you are not around the corner Phil so we could try.
    Sent via Tapatalk
    Source: Win10 server, Win10 Mini-ITX Renderer running JRiver & Tidal/Roon
    DAC / Preamp: Perreaux DP32, Secondary DAC:
    Chevron Paradox
    Amp: Radford Revival STA25, TubeHunter Class D IRS2092
    Speakers:, Tannoy Eatons, Kudos Cardea C2, BatPure Supertweeters (and others)
    Power Conditioner: ISOtek Qube 1k
    Currently resting: Radford Revival Prototype preamp, Paul Baldwin 405C amp, PMC LB1 Signature
