Looking to upgrade my RB250, deck is an SRM Arezzo ultra. Love the look of origin live encounter maybe even illustrious or the cheaper audiomods micrometer.
Wondering if anyone has experience of different arms on an Arezzo.
TIA Allan.
I'm Allan.
TIA Allan.
I'm Mel.
Audiomods is great and can be made to your exact requirements at no extra cost.
I used to like origin live but they seem to have lost the plot and become too profit orientated.
At least that’s my view as you asked for
Mel
I had an Arezzo but had the standard arm on. One of our members had one with a fancy Aussie or N Zealand arm on. My memory is not what it was tonight alas.. pain getting in way lol
It wasn't "The Wand" by any chance?
Edit: I meant the tonearm, nktnthensource pf your pain lol
That was it yes
I'm Allan.
Thanks for advice so far, will make a decision in a week or so. Hope you feel better soon Grant.
I’ve run the OL Encounter for a couple of years now. SQ is excellent and is a huge leap up from the RB250. Currently running the Hana SL in it but will soon be changing back to a Ortofon Cadenza Black. My only 2 niggles with it are the fixed headshell and the fact that there are no weight marking which makes setting tracking a bit of faff.
I would like to upgrade to an arm that does include those 2 features but am worried that the SQ will be poorer unless I spend silly amounts of money.
TV LG55B7 OLED
I'm John.
I don't know or have experience of your deck, but am also currently running an Encounter 3C with a Hana SL and it's a superb arm. Having the RB250 have you considered sending it to OL for their rewire and structural upgrade, I think it works out at around £200 and really elevates the 250 into another league.
I'm Charlie.
Allan,
If you have enough in the budget to buy an Illustrious and you're patient, why don't you get a Schroeder Model 2 at £1695 (less than the new price for the Illustrious)? The Schroeders have a great reputation for sound quality and they are all hand built by Frank in Berlin. It has standard Rega tonearm geometry and so it should fit your TT without any significant modification.
https://www.coolgales.com/product/sc...del-2-tonearm/
It's a bit more fiddly to set up, but the thread and magnet bearing works really well with any cartridge (subject to mass considerations).
Charlie
R2R: Studer A820 1/2 inch 2 track; Otari MTR-12 1/4 inch 2 track; Sony APR 5003; Sony APR 5002; Studer A807/II. Vinyl: Platine Verdier Allaerts MC1B/Schroeder Reference & Model 2 Decca C4E/Hadcock 228 TRON Seven Reference phono. Keith Monks MkII RCM Other analogue source: Nakamichi Dragon with ANT4066 mods. Amplification: TRON Meteor preamp TRON Voyager 20B SET power. Speakers: Avantgarde Duo. Digital: computing at last with Prism Sound Lyra 2 A2D converter
