I'm Ian.
Delivered this afternoon. I’m now on my third album and first impressions are very positive. I’m currently running off the stock Pi power supply but it still offers a clean and open sound via my DAC.
Yes it sounds good with a basic power supply, though I found a significant improvement with this: https://www.audiophonics.fr/en/hi-fi...a-p-11364.html
Geoff
I've just ordered a Digione Player from Allo and have a quick question.
Am I best to use a USB stick with my music on plugged directly into the Pi or stream from a hard drive plugged into a PC?
Chord Mojo / Sennheiser HD600
Either will work fine so long as you have a good connection between the RPi/Digione and your router (ideally, Ethernet). The only downside to a usb stick is the size limitation. I am currently transferring my flac files to an 8tb Western Digital network drive.
Geoff
I used a 1TB WD my passport usb hard drive with my RPi with no problems.
I have used that same combination but stopped using it as I detected a reduction in sound quality, most noticeably in dynamics. I think it may be because the WD Passport takes its power from the RPi USB and it draws a much higher current than a solid state USB stick. If possible I would connect it via your router or your main PC.
Geoff
Interesting.. I moved to using a self powered WD my book and it improved my sound. was told it was better this way.
