Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 93
Thread: WTF ?
  1. #81
    I think you're meant to smoke the contents!
  2. #82
    Bigman80 Guest
  3. #83
    How come glass tubes filled with stuff attract almost universal derision, whereas using oak feet or those little bags, attaching expensive mains cables or polishing fuses, non of which, correct me if I’m wrong, have any scientifically proved evidence to support them, are readily accepted?
  4. #84
    Quote Originally Posted by RMutt View Post
    How come glass tubes filled with stuff attract almost universal derision, whereas using oak feet or those little bags, attaching expensive mains cables or polishing fuses, non of which, correct me if I’m wrong, have any scientifically proved evidence to support them, are readily accepted.
    Boom boom
    By some.
  6. #86
    Has the website been written by this man http://www.telegraph.co.uk/culture/f...debunkers.html ??
    Remember has IC challenge?
    PRE
  7. #87
    OK, here's some more to rattle a few sabre's
    http://archive.randi.org/site/jr/121004science.html#11
    PRE
  8. #88
    I don't know about anyone else but for me it is a sliding scale, running from, maybe, mains cables at one end down to the nuttiest Machina Dynamica stuff at the far end. I'm sceptical about all of them but some seem more credible to me than others. I don't give anything a free pass. Why should I?
  9. #89
    I'm Pavel.
    I think it might be possible for a mains cable to affect sound if it somehow restricts the amount of current that can pass through it. 2.5 square mm of “ordinary” copper is more than enough for 10A (that’s 2300 VA), and that’s precisely what’s inside your walls. Even if the last 1.5m are made of snake-like triple-insulated silver-plated LC-PC-OCC-WTF stuff, it’s not going to make a difference.
    That said, I’m guilty of buying a couple of (formerly expensive) hi-fi mains cables on eBay because I think they look pretty
  10. #90
    I'm Russell.
    It may be OK for some lay persons to believe in magic, but I’m an educated man, I know all about the properties or electricity. If I can’t think of a single plausible reason why something might work, then I can’t make that leap of faith that it may work! In fact, if I heard it and it did work, then It would bother me so much that I couldn’t enjoy it! I don’t know exactly why a better mains cable may work, but I can at least imagine a few reasons why it does. It may be as simple as a larger ground wire? Isolation from radio signals and magnetic waves from transformers? At least it’s in the path of the electrical circuit!
    Then there are the claims. Why is the material in the tubes a secret? If it worked as well as claimed, don’t you think another accessory company could just open one and analyze what’s in it? They offer no reasonable reason why it works, the only thing they have going are testimonials. All of these are the behavior of most other snake oil salesmen. Have you tried the $330 carbon fiber wall socket cover? The $6 plug strip that is supposedly cryogenically frozen, for only $290? All advertise their products in the exact same way.
    But this is just me, if you hear a difference and love them, more power to you! I’m not going to judge, if you’re happy, I’m happy. It’s just not for me, I could never reconcile my need for scientific evidence and reasoning. My personality flaw I suppose.
    Russell
