You might get an effect if you snort the contents?
Ah. Reggie Got it on DVD somewhere
How come glass tubes filled with stuff attract almost universal derision, whereas using oak feet or those little bags, attaching expensive mains cables or polishing fuses, non of which, correct me if I’m wrong, have any scientifically proved evidence to support them, are readily accepted?
I don't know about anyone else but for me it is a sliding scale, running from, maybe, mains cables at one end down to the nuttiest Machina Dynamica stuff at the far end. I'm sceptical about all of them but some seem more credible to me than others. I don't give anything a free pass. Why should I?
I think it might be possible for a mains cable to affect sound if it somehow restricts the amount of current that can pass through it. 2.5 square mm of “ordinary” copper is more than enough for 10A (that’s 2300 VA), and that’s precisely what’s inside your walls. Even if the last 1.5m are made of snake-like triple-insulated silver-plated LC-PC-OCC-WTF stuff, it’s not going to make a difference.
That said, I’m guilty of buying a couple of (formerly expensive) hi-fi mains cables on eBay because I think they look pretty
Has the website been written by this man http://www.telegraph.co.uk/culture/f...debunkers.html ??
Remember has IC challenge?
