Results 1 to 4 of 4
Thread: FS: Turntable Cover - very nice
    I'm Josie.
    Default FS: Turntable Cover - very nice
    Hi all.
    This will no longer fit my turntable so it's up for sale.
    It was quite expensive to buy new. Had it specially made out of 5mm acrylic.
    Its in super condition, only very minor blemishes here and there, nothing you can see unless under scrutiny. (the lines you can see on top are just reflections)
    It has black velvet pads but these are only stuck on and I can remove them if needs be.
    It has a cut out hole for cables and handles which was a special request.
    Size is H:20.8cm x W:46.5cm x D:42.5cm
    Cost me £120 asking £90 plus post.
    PayPal giftywoo please
    Thanks
    Sent from my 9001X using Tapatalk
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I'm Neil.
    Josie can you put a reserve on this so I can check the measurements it, might suit a deck I have but I need to measure and I am not back home till 6 pm tonight, confirm then if it will work for me.
    Regards Neil
    I'm Josie.
    Hi Neil.
    Sure, no probs.
    Which turntable will it be for?
    Tannoyista.com
    Facebook
    I'm Neil.
    Hi Neil.
    Sure, no probs.
    Its to do with the height of the arm, less the foot print.
    Regards Neil
