Results 21 to 30 of 44
Thread: Speaker Box Suggestions Request
  1. #21
    I'm Mark.
    I think there's usually a pedal on the floor of those vehicles which the driver can use to control the speed. Don't press it down too far and it won't go too fast.
    I learned that - a little late!!!
    Sent from my LG-H850 using Tapatalk
  2. #22
    I'm Mark.
    Actually, those drive units are almost asking for a Sonab style semi-omnidirectional cabinet.
    Interesting!
  3. #23
    I'm Mark.
    They don't sound too shoddy actually - a little strong in the midrange.
    I'll hook them up to my Quad 306 next week...
  4. #24
    A forward mid makes them even better candidates for an omni type application. It may sound daft, but as an experiment, lay them on their backs with the tweeter angled so they aim towards the real wall and have a listen.
  5. #25
    I'm Mark.
    Wow! Yes - much better!
  6. #26
    Thought the results might be interesting. The imaging will be diffuse, but that can be pleasant. You will still get a stereo image though, but a large one.
  7. #27
    Another thought. Car speakers are usually well magnetically damped, enabling them to be used in all sorts of 'ill terminated' mounting positions. This means that they should respond well to reflex loading. In other words, a well chosen bass port should beef up the bass nicely.
  8. #28
    I'm Mark.
    This is fun!
    I might hole saw a port - the 'well chosen' is the toughie though!!!
  9. #29
    length of port may be more important than size of hole. you can buy variable tubes that you can play around with
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, DEEZER HiFi - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
  10. #30
    Quote Originally Posted by M6NTL View Post
    You need to know the fundamental resonance of the driver and the cabinet volume.
    I doubt you'll find info on the driver, but you might, T/S parameters would be handy. I can have a stab at a guesstimate if you like. What's the outside diameter of the driver? There'll be a port calculator somewhere. I have a set of ancient but very appropriate G A Briggs tables knocking about.
