Results 1 to 8 of 8
Thread: Vortexbox help
    I'm gerald.
    Default Vortexbox help
    I am trying to install vortexbox on a old laptop running windows 10 .I have created a bootable usb installed vortexbox but nothing is showing when computer reboots ,I have been into disc managment to check and there is no 4gb section there any ideas its version 2.4
    might have to set pc to boot from usb first. other thing is did you use something like win32disc to make the bootable usb
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/M55E/EMOTIVA XPS1 - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, DEEZER HiFi - SMSL M6 MINIDAC - RPI/AUDIOPHONICS - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm gerald.
    done all that after install it says remove usb and reboot but it does not show the 4gb partition that it should create? even been through disc managment.
    if the usb is showing empty then its not worked is all i can think. you might not be able to see whats on it but it should register as being there
    Grant ....
    I'm gerald.
    the usb is supposed to install a 4 gb partition on main drive then you go I to that and set up vortex
    have you got view hidden items ticked when looking for it? go to drive then click view at top then tick hidden. might be hidden
    Grant ....
    some pcs dont like booting off of a usb. ive got one that just wont do it. can you put the boot prog initally on a blank dvd? and boot from that
    Grant ....
    I'm gerald.
