lets see a pic from the other side with the solder joints,it may help identify a problem
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Did you snip the wires off the back before replacing, they look like they are crossing the pcb traces?
I see a couple of soldered joints that look as if they may not have 'flowed' properly. Might be worth looking at.
I removed the old caps with a desoldering pump and then cleaned up with some braid. I then inserted new caps, bend wires, solder and then clip wires.
Sent via Tapatalk
Is there any way I can test the xovers using a multimeter?
I did read the tweeter using a mm. I think the tweeter needs replacing as it read ca. 27 ohms.
Sent via Tapatalk
It could do. Seems to me that if you haven't got a complete circuit then current won't flow.
