yup.....gaz said to me-last speaker you will buy!!!
He is maybe right!
I'm tony.
He is maybe right!
I'm Colin.
Hi Tony,
So glad you are liking the speakers. It was a pleasure to build and develop these for you and yes they do really cut the mustard don't they. The tweeter is the Satori TW29RN-B which is the neo magnet version of the standard Satori tweeter. Well worth paying the extra over the standard as you can clearly hear the benefits. Scott did a brilliant job of redesigning the filter for these and Chris and me only needed to do minor tweaking to a resistor change to get them on song during the listening fine tuning.
In fact so pleased are we of this hybrid that it will be offered as the EDINGDALE SR, an upgrade version to the standard Edingdale MKII that is in itself an improvement on the original MKI as testified by all that have the heard the MKII and also have heard the MKI or are owners of the original MKI Edingdales.
Just a few points to clarify.
Tony now how can you get your hardwoods mixed up? The speakers are finished in Oak veneer NOT Walnut as we agreed early in the build.
The efficiency of the speakers is a conservative 95dB and a benign nominal 8-Ohm load.
The speakers may look large but are a modest 110cm high x 40cm deep and 25cm wide, around 80L cabinet volume. They take up no more room than your average standmounts. They are also very tolerant to room position and can be placed quite close to a rear wall.
They are as happy being driven by a 300B 5W SET amp as they are using 120W MosFet SS amps, T-amps (Chip amps) or 60W push-pull valve amps. So you can just about throw any amp at them and get stunning results.
I'm Colin.
I'm Colin.
Oh I forgot to mention that apart from offering the hybrids as Tony has got we are also developing an all Satori driver version of the Edingdales with the TW29BN-B SATORI BLACK BERYLLIUM DOME TWEETER. This speaker has promises to be even better than the SR version. However this a few months off before they will be ready.
I'm tony.
Colin,
Im delighted with them...apologies regards the finish mistake-Lou dictated that!!(which greased the wheels WAF wise!).
your constant build upgrade e mails were wonderful-glad i took your advice re the tweeter, money well spent IMHO.
Im just in awe at what you have produced, aesthetically and sonically.
Moved them further out from the fireplace, to let them breathe a bit.
They deserve top notch cabling by the way...
EWA stuff winging its way to me (gaz runs tq ultra-thought WTF if im doing it right go all the way!!)
Thank you.
I'm Nigel.
Evening Colin,
Will you have a set of these ready for a demo as and when I drive up with Geoff to collect his MK11 version?
Nigel
Hi Colin,
Nice to see you popping in again, and I hope you are well
You have a PM
I'm Colin.
Hi Nigel,
I managed to persuade Geoff that the hybrids were worth paying the extra as the upgrade in performance more than justifies the small increase in cost. So yes you'll be able to compare the hybrids against the MKII's my place. Just started the build so hopefully they will be ready for when Geoff gets back from his OZ holiday.
I'm Nigel.
